Just installed the 2.9.35 to a HDD, moved the HDD to other computer which will be the router and completed the installation.
It then get to the point when I enter username and password. Default ones worked well (admin / nothing)
It then showed me that I have 23h59min to Licence the router. OK, I pressed enter and got to the
admin@MikroTik: _ console…
And there the problems start. Whatever I typed into a console from this point on, I would just be redirected to the Login again. And I login again and type “setup”, it just appears “Login” again. I try to type ? to see commands, but just after i press the ? button, it goes again to the Login… and keeps looping…
So no way to set it up… even those basic thing so I could access it from Winbox…
Can anyone help what to do or do I really have to reinstall it…
Thanks!
