2.9.37
On RB112 this version completey breaks the ethernet port.
After upgrade no-link on the ethernet. I downgraded it to 2.9.29
now the ethernet works again ???
Jman
we found out that the problem is that the MDIX on ethernet ports isn’t working correctly on RB100 series boards. We will fix that in v2.9.38.
2.9.36 introduces new problem with ethernet.
2.9.37 suppose to fix it, but it doesn’t
Come on…
that’s another problem. ethernet works fine in 2.9.37, but you have to use the correct cables.
So you broke something and then broke something else fixing what you broke in the first place?
Thats some find QA you got going on over ther
there was a mistake in the testing system, we fixed it and from now on, the releases will be much more tested than before. any version that will be released from now on, will undergo many major setups on many different systems for a prolonged period of time.
