*) fixed scheduler to notice clock changes;
*) fix for miniRouter ethernet tx stop;
*) improved performance of user-manager;
*) some fixes in USB UPS report handling;
*) fixed line power monitor to also work with USB UPS;
*) added workaround for WinBox freeze under latest Wine;
*) added support for Huawei Mobile Connect Model E620 (3G);
*) added support for Novatel Merlin S720 (HSDPA);
*) fixed encrypted link establishment when using nstreme;
2.9.39 introduces improvements for the links running Nstreme+encryption, there should not be any problems with Nstreme/Encryption links establishing right now.
If you will run to any problems, then contact support (support@mikrotik.com) with attached support output files and problem descriptions.
I was messing with this today, on a couple of 2.9.38 boxes - it would connect, then disconnect a moment later. Updating to 2.9.39 resolved the problem. Just sort of a confirmation for any searchers…
Yep, using static keys. Nothing fancy, just making sure the odd wardriver doesn’t get any ideas.
It drops every 16th ping or so and given client feedback, this includes any packet. Seems something administrative/automated within the AP/Router but no one knows what it could be.
