2.9.43 multiple gateway
Hi I ran Routeros on an amd PC with usermanager. I have two ADSL routers connecting to the internet. When I try to set the gateway to 0.0.0.0/0 to these two routers the os set the second one’s ip to be the same as the first one as soon as I apply the setting. I downgraded to 2.9.41 and everything is running smooth, but as soon as i upgrade to 2.9.43 it does the same thing.
