jorj
September 29, 2007, 6:48am
1
The demo.mt.lv shows this:
Trying 66.228.113.24...
Connected to 66.228.113.24.
Escape character is '^]'.
MikroTik v2.9.48
Login: demo
Password:
MMM MMM KKK TTTTTTTTTTT KKK
MMMM MMMM KKK TTTTTTTTTTT KKK
MMM MMMM MMM III KKK KKK RRRRRR OOOOOO TTT III KKK KKK
MMM MM MMM III KKKKK RRR RRR OOO OOO TTT III KKKKK
MMM MMM III KKK KKK RRRRRR OOO OOO TTT III KKK KKK
MMM MMM III KKK KKK RRR RRR OOOOOO TTT III KKK KKK
MikroTik RouterOS 2.9.48 (c) 1999-2007 http://www.mikrotik.com/
Terminal unknown detected, using single line input mode
[demo@demo.mt.lv] >
Router running for at least one day.
The download page shows us 2.9.46 for both x86 and routerboards.
Any changes made ?
jorj
October 19, 2007, 11:18am
3
ste
October 19, 2007, 12:26pm
5
*) fixed bug in routing-test package;
What bug? Don’t know wether it makes an update neccesary.
Stefan
Hold on to your subnets boys…
That comment makes me all warm and fuzzy !!!..
normis
October 22, 2007, 8:19am
8
it mentions a bug, it’s not actually a “problem”. it’s hard to tell what problems a bug caused, probably different kinds. if users report problems, we look for causes. then a bug is found, fixed and this solves the reported problems. usually one bug can cause many problems, but it’s not possible to tell what problems as configurations are many.
ste
October 22, 2007, 9:32am
9
normis:
Hi Normis,
what I wanted is some feeling wether to update or not (some sort of
severity-Information) That’s what release notes are for.
“fixed a bug” is no information. I know there are bugs. Even a good programmer
makes at least one bug every 4k of source code.
So if you say it’s “not actually a problem” it’s a bug which not likely kills
one of my ap’s. So I’m happy and do not touch my running systems.
Stefan
ste
October 22, 2007, 10:00am
10
found the wireless-crd package. Gives me two countries for
the additional frequencies in germany. Thanks MT
(waiting for the A-TP stuff in 3.0 to have the full power ).
But for some short shot’s it’ll be real helpful.
To change to the new frequencies with winbox you’ve to
select a band with frequencies which are available in both
“countries” e.g. 5GHz-10MHz, select the new country and
then select 5GHz again. So I see the 5 frequencies in upper
Band.
What I’m wondering. I tried this with a R52h and saw
24db outputpower with 5-24MBit (ok) but I saw lower
power at higher speeds.
[admin@a14] > interface wireless monitor wlan1 once
status: running-ap
band: 5ghz
frequency: 5770MHz
noise-floor: -103dBm
overall-tx-ccq: 67%
registered-clients: 0
authenticated-clients: 0
current-ack-timeout: 25
current-distance: 25
nstreme: no
current-tx-powers: 6Mbps:24,9Mbps:24,12Mbps:24,18Mbps:24,24Mbps:24,36Mbps:22,48Mbps:20,54Mbps:19
notify-external-fdb: no
R52h should have enough power to give 24 at 54Mbps too ??
[admin@a14] > interface wireless print
0 ;;; w1
name="wlan1" mtu=1500 mac-address=00:0C:42:18:0F:86 arp=enabled disable-running-check=no
interface-type=Atheros AR5413 radio-name="w1" mode=ap-bridge ssid="xxxxx" area=""
frequency-mode=regulatory-domain country=germany 5.8 fixed p-p antenna-gain=0 frequency=5770
band=5ghz scan-list=default rate-set=default supported-rates-b=1Mbps,2Mbps,5.5Mbps,11Mbps
supported-rates-a/g=6Mbps,9Mbps,12Mbps,18Mbps,24Mbps,36Mbps,48Mbps,54Mbps basic-rates-b=1Mbps
basic-rates-a/g=6Mbps max-station-count=2007 ack-timeout=dynamic tx-power-mode=default
noise-floor-threshold=default periodic-calibration=default periodic-calibration-interval=60
burst-time=disabled dfs-mode=no-radar-detect antenna-mode=ant-a wds-mode=disabled
wds-default-bridge=none wds-default-cost=100 wds-cost-range=50-150 wds-ignore-ssid=no
update-stats-interval=disabled default-authentication=yes default-forwarding=yes
default-ap-tx-limit=0 default-client-tx-limit=0 proprietary-extensions=post-2.9.25 hide-ssid=no
security-profile=yyyyy disconnect-timeout=3s on-fail-retry-time=100ms hw-retries=15
preamble-mode=both compression=no allow-sharedkey=no
Stefan
