2.9.9 bridge bug?
Hi folks!
I’m upgade MT from 2.9.8. to 2.9.9 on RB230 & RB532. After upgrade Winbox, Dude (via SNMP) can’t show current traffic volumes on bridge interface, but on real intefaces (ports of this bridge) traffic showing correctly. This is ok?
bridge is changed in 2.9.9, please check your configuration
I set up my router last evening (from a complete reset) and i had same effect
traffik was only shown on real interface and not on the bridge device…
Ciao Gerd
Resolved. Disable+Enable bridge interface restore normal traffic counters!
?? i upgraded to 2.9.10 and had a complete reset
now i have wlan1 and ether1 in the bridge on both i can see traffic but not on interface bridge1 (also when i watch thes graphs…even when i wharch in winbox…)
Ciao Gerd
Still no comments ?
It set it up and i also saw no traffic on the bridge enabling disabling bridge solved this problem temporary… after a conrolled system reboot same => no traffic shown on bridge interface.
At this moment this might work for me , but when i’m connected to that bridge .. how to do this ? You lost connection and have to climb upstairs with a laptop to solve this… :frowning:
Ciao Gerd
Bug?
