If anyone would like to test the 2.9 RC version, you can try http://demo2.mt.lv
What is the login user for webtool??
it’s not the same for demo router winbox
webbox is not available for demo users yet
What is the login for Winbox?
Username “demo” without password.
Also, now you can access the webbox with demo user.
Why the CPU LOAD is ever at 100% ?
it should work fine now.
If somebody do not notice, than webbox feature now is available for demo users. ![]()
i can`t connect to demo router via telnet or via winbox or webbox…
It will be everything all right soon, please, be patient.
just tried doesnt work with winbox
works now
looks like its down again ![]()
no, both demos are working
I am using 2.9 RC9 but i also face the same problem. My cpu load show 100%. I cannot access webbox. But everything working fine
Hi
I have the same problem.Moterboard with AMD processor and 100% utilisation. Few days ago did upgrade from 2.9 rc7 to rc9. Before all works ok, now after few hours always have 100% processor load. Working only telnet-ssh connection. The only way to resolve this problem is reboot router. Its AMD processor question?
with rc10 the same situation ?
I did remote upgrade to rc10 3 hours ago. Had some affraid (router is about 6 km away from me on roof 10floor bulding) but working fine. Processor have normal load (up to 60%).
I upgrade RC10. Now cpu load is normal avg 10%. ![]()
