2.9: problem, lost connection after 5 minutes on rb500
Since 2.9rc10 on rb500: after 5 minutes work disconnect. Aftrer reboot works fine but only 2-5 minutes. tested versions 2.9rc10 2.9 and 2.9.1. on 2.9rc9 works fine.
two rb500 configured to nstreme2 with cards atheros 5213 without compression. standard config with nstreme (5ghz non turbo) with bridge eth0-nstreme0.
please make the support output files from both routers and send them to support@mikrotik.com so we could check where could be the problem.
what have i set to generate all need logs?
/system sup-output
This will create a supout.rif file which you can download from the router via FTP or SCP…
