2.9 RC 4 ....
posted and coming down the wire …
from the changenotes:
What’s new in 2.9rc4:
*) fixed via driver for RB500;
What’s new in 2.9rc3:
*) fixed radius-mac-authentication bug in wireless;
Up and running on 4 base stations :wink:
No problems (as with rc1 and rc2), but wireless settings is lost after reboot.
Installed on PC = Great… :smiley:
Installed on RB500 and BOOM! No kernal.. :open_mouth:
Have sent msg to support, expect to here about fix tonight… :wink:
So I am batting about 500.. Hmmm strange… :confused:
Craig
Put it on 3 high-speed test routers yesterday (1 to 1.5GHz CPUs, 3 different types) and it seemed perfectly stable in wired throughput tests (98Mbps ethernet to ethernet). Not tested with Wireless yet.
Regards
Working fine on a Dell 400SC server on our backbone, 7 miles away from our tower. 70 subs running off the tower, rc4 throttling and addressing them all with no problems so far. I did notice after the move from 2.8 to rc2, the queue display is alot more sluggish than before, was the refresh rate turned down a little in 2.9? Also, would someone mind zipping and sending me the original html files? I screwed up and accidently deleted them all and the folder they were in…
Tommy J.
RC4 Working fine on 4 base RB532 routers. and i think the problem with the wlan card loses the clients is gone :slight_smile:
Installed on a Via based router box with Atheros card, and I get the following errors when trying to ping the wireless IP:
92 bytes from 10.0.1.1: Dest Unreachable, Bad Code: 9
Vr HL TOS Len ID Flg off TTL Pro cks Src Dst
4 5 00 0054 c392 0 0000 40 01 a018 10.0.1.254 10.0.1.1
//EDIT: I just downgraded the router to 2.8.27, and everything is working properly, so…
//EDIT2: More info would probably be useful. The wireless card is reported in 2.8.27 as an Atheros AR5213, and I tried several B/G/combo settings, with no change.
-=Russ=-
Just found another possible issue. Try dragging your queues around a little. About every 10th move, it will completely lose it’s information in that queue.
I was trying to get all of mine in numerical order by IP and lost 3 of them…
Tommy
rc4 issue ? i added some dst-nat rules and for some reason the router will not allow me to move them up or down.
did not have this issue in rc2. this is on a p4 system not that it matters.
any one had this issue.
randy
Problems with RC4 the clients get conected every 25 seconds ??
but it works:-) my log is full with wlan conected.
i will send the supout file.
OS2.9rc4
I have unchecked “default Forwarding” in wireless interface menù but registered client still to comunicate with each other!!
Is a bug?
thanks
If you add an ip pool and dont select any ip the winbox app crashes.
Dean
