Ive upgraded a 532a with an sr9 card to beta 9 and tried to connect a cpe 112 with Sr9 running 2.943 I cant see the ap
I then upgraded the cpe to beta 9 which made board useless sense then i reloaded same cpe with beta 8 and can connect to the Ap with no problem
Is the beta not compatible with 2.9 version??
you can see the other 2.9 AP/CPE in align mode, but you cannot see it in scan mode. I have this same problem, the 2 versions do not seem compatible when using SR9 ?
Sam
this problem is not present using standard cm9!
I can see my beta9 AP using 2.9.43 cpe.
Regards
correct, i thnk its possibly only SR9? I had 3 different routerboard pairs with the same issue.
as a side note, i just finally after weeks troubleshooting my 3.0beta9 truck radio with major duplicate ACK wireless packets downgraded back to 2.9. Instead of the 100-200kbps throughput I was getting I now am getting the 8-10mbps I previously was getting. For some reason in only one direction performance was horrible. I have pcaps if interested. I replaced radios, changed wireless settings up and down, nothing helped. Rolled back to 2.9 and it’s perfect again. There is something weird with wireless and 3.0b9.
Sam
did you check the tx/rx rate attributes, i noticied that since 2.9.40 they changed from bytes to bits. So maybe you are only getting the wrong setup about the client from your radius.
I lost some hours when I upgraded from 2.9.38 to 2.9.43 to check what was going…
Ros
