2 AP + Mikrotik + Userman
I have a 2 Netgear + 1 Mikrotik … is possibile to user Usernamn for other AP ?
i want that when a client is associatet a NETGEAR … the client must be insert usernam e password in hotspot
how i can configure Mirkotik + hotspost for user the radius + capitive portale also for other AP on the same lan?
thanks
Depends on the Netgear. If the Netgear has ‘captive portal’ and radius authentication support, then it might work.
tnx a lot.. but if i set the other ap with Mikritik gateway..is not possible to use the Mikrotik captive portal?
the captive porta is possible to use only for local mikrotik ? is possible to use the autentication pager for others APs?
tnx a lot
I suggest you read the documents for your Netgear to find the answers to your questions. The Mikrotik can provide a RADIUS Server and you may possibly be able to use this with the Netgear. You may have to provide a new captive portal server. I do not know how the Netgear works, only the Mikrotik.
