2 AP's on 1 hotspot
Hi
I have been using the Mikrotik router for 5 months now with great success. I use the hotspot feature and its really easy to manage and configure.
Now that my networks grown i would like to add another wifi card to the existing hotspot configuration to expand the hotspot.
How do i do this? Even giving me a good head start would help as i have to do this with minimum downtime?
Thanks in advance
SHaun
you want to have another HotSpot network in this Router ?
than simply insert wireless interface, and run ‘ip hotspot setup’.
I would prefer the 2nd wifi card to be part of the 1st hotspot. Is it possible?
create bridge interface between wlan interfaces and run your hotspot on bridge interface (IPs, DCHP too). remember to block transfer from one interface to other with bridge firewall
