2 boards cable connection >>> help
Hi
I need an advice
I have 2 mikrotik boards 433ah working as access points together
one is recieving the net by XR 5 then sending to client by XR2
no problem here
then the other board connected to the firest by ether cable
and set as pppoe server sending to users by 2 XR2
all port are set as bridge
now
what is the best way (using the ether cable) to connect the second board to send the net to user with same setting of the frist ?
sorry for bad english
please help
I’m realy in bad situation
UP
:frowning:
up again
:open_mouth:
