2 Bugs? Problem with large subnet and default route
This looks like a bug in Mikrotik, I am not positive but it should be easy to verify.
The ISP has a large subnet 255.255.192.0.
The IP assigned to me:
IP: 69.178.7.221
MASK: 255.255.192.0
BCAST: 69.178.63.255 (Must be set manually, Mikrotik doesn’t set this correctly (bug 1))
Then assign a default route of:
69.178.0.1
Mikrotik will be unable to determine which interface the default route is on. It cannot be set manually either. I have checked the subnet, mask, broadcast, and route and they are all correct. Everything looks like it’s correct but the Mikrotik cannot tell where the default route should go. (bug2)
I have tried this on another version of Mikrotik on another a 532 with the exact same results as well. This seems very basic and shouldn’t be a problem.
If this requires a new version to fix, is there a workaround that can be used temporarily?
I have also sent a message to support.
Thanks,
  • Dan
dan_99503 -
What version of MT RB OS are you using? I’ve tried the below on 2.9.31 - 2.9.45 and had no problem putting in the address - I put in like this (because I was lazy and didn’t want to calculate the /mask) 69.178.7.221/255.255.192.0 MT calculated the mask as a /18, let me put in a route to it as well and identified the correct interface as you can see below…
Check under system menu, see if the routing package in enabled (and which one - routing test or routing) - some versions of MT came w/routing package disabled…that could be issue - doubtful though…
7 address=69.178.7.221/18 network=69.178.0.0 broadcast=69.178.63.255
interface=Public actual-interface=Public
Thom
Thom,
Thanks for your input. The Mikrotik support folks got back with me and it was my mistake. I was not paying close enough attention and put the netmask in for the network and that’s why they both failed.
