2 card and 4 vpls tunel, not working, help!!!!!!!!!!!!
I’m trying to run 2 vpls tunnel through one card and 2 through the other, one works the other does not!
The problem is that, on one card (wireless) operates a tunnel to cheer, even for two routerbord at the same time I want at the same routerborde insert a second card and add another tunnel along the lines that he simply does not work! Help tunnels run for a second card! or what I’m wrong, I attach screenshots, thanks in advance!
For Russianhttp://forum.ru-board.com/topic.cgi?forum=8&topic=38493&start=560#lt
Use search, this topic was covered in details
Here is an example setup
http://wiki.mikrotik.com/wiki/Transparently_Bridge_two_Networks_using_MPLS_extended
you have not understood correctly, the channels do not have sumirovat all four of the tunnel will vpls diverges into four different routerbord
You need to set u loopback interface, add loopback address, set up ldp transport address and make VPLS tunnel to loopback addres.
show by example how to do it right
may be the reason?
I have to routerborde 2 cards are connected through three houses, each on routerbordu.Ya wanted to do for each VPLS tunnel.
2 houses are hanging on one card and 2 tunnel already working, I can not get to work 3 tunnel through another card
I combined the two wireless cards in the bridge and added it to the MPLS interface. set bridge address 192.168.77.1 and ordered him to set up connections to other VPLS routerbordah and created a connection on it for each board to its ip and individual id.
Added all VPLS connections to a separate bridge and add the ethernet (similarly done with connections to be connected to the base boards).
What does not work:
connections to all routerbordy work but interesting
on one card and ping and the data leave
And the other is not given that konekt VPLS tunnel shows that works!
and ping with routerborda through this card is coming!
screenshot attached
Developers! Help !!!
developers don’t post here
