2 card Wireless repater
I have RB912UAG-2HPnD-OUT (Basebox 2) with additional mPCI wireless card (Atheros AR9300). I can’t create wireless repeater with pulling DHCP from source router. I’m succesfully connecting to existing network on wlan1 and broadcasting second network on wlan2 but cannot connect to it. Tried creating DHCP Server and then Relay to source adress but it’s not working. I can’t use WDS there.
wlan1 → connect to existing network
wlan2 → redistribute network
This is my current setup.
add name=bridge1
/interface wireless
set [ find default-name=wlan2 ] band=2ghz-b/g/n channel-width=20/40mhz-Ce \
    disabled=no mode=ap-bridge
add authentication-types=wpa-psk,wpa2-psk eap-methods="" group-ciphers=\
    tkip,aes-ccm management-protection=allowed mode=dynamic-keys name=test \
    supplicant-identity="" unicast-ciphers=tkip,aes-ccm wpa-pre-shared-key=\
    secret wpa2-pre-shared-key=secret
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n disabled=no frequency=2422 \
    mode=station-pseudobridge security-profile=test ssid=COMTREND
add name=Local1-Pool ranges=192.168.2.11-192.168.2.100
# DHCP server can not run on slave interface!
add address-pool=Local1-Pool disabled=no interface=wlan2 name=server1 relay=\
    192.168.2.1
add bridge=bridge1 interface=wlan1
add bridge=bridge1 interface=wlan2
add address=192.168.2.1 interface=wlan2 network=192.168.2.1
/ip dhcp-client
add default-route-distance=0 dhcp-options=hostname,clientid disabled=no \
    interface=wlan1
/ip dhcp-relay
add dhcp-server=192.168.1.1 disabled=no interface=wlan1 local-address=\
    192.168.2.1 name=relay1
add address=192.168.2.0/24 dns-server=192.168.1.1,8.8.8.8 gateway=192.168.2.1 \
    netmask=24
/system clock
set time-zone-name=Europe/Warsaw
/system leds
set 0 interface=wlan1
add interface=wlan2 leds="wlan2_signal1-led,wlan2_signal2-led,wlan2_signal3-le\
    d,wlan2_signal4-led,wlan2_signal5-led" type=wireless-signal-strength
add interface=wlan2 leds=wlan2_tx-led type=interface-transmit
add interface=wlan2 leds=wlan2_rx-led type=interface-receive
/system routerboard settings
set cpu-frequency=600MHz init-delay=0s protected-routerboot=disabled
Use station bridge for wlan1. Set administrative mac address to bridge1. Remove dhcp server and all ip settings and set dhcp client to bridge1.
I have to set Admin mac addr. in bridge1 to itself?
Yes.
So MAC Addr. of bridge1 is set by default to ether1. And still I can’t get IP on other devices from DHCP.
Have you done all the things I suggested?
Yes, exactly.
Paste your actual export here again.
I noticed that wlan1 refuses to connect to existing Wi-Fi network when in station bridge mode. In station or station pseudobridge it’s connecting to the existing network but devices still cannot connect to mikrotik network.
I propably should say that my source router is not a MikroTik router.
Here’s current config, with verbose hiding sensitive:
add admin-mac=6C:3B:6B:51:9E:64 ageing-time=5m arp=enabled auto-mac=no \
    comment=defconf disabled=no forward-delay=15s max-message-age=20s mtu=\
    auto name=bridge priority=0x8000 protocol-mode=rstp transmit-hold-count=6
set [ find default-name=ether1 ] advertise=\
    10M-half,10M-full,100M-half,100M-full,1000M-half,1000M-full arp=enabled \
    auto-negotiation=yes bandwidth=unlimited/unlimited disabled=no \
    full-duplex=yes l2mtu=1600 mac-address=6C:3B:6B:51:9E:64 master-port=none \
    mtu=1500 name=ether1 orig-mac-address=6C:3B:6B:51:9E:64 rx-flow-control=\
    off speed=100Mbps tx-flow-control=off
/ip neighbor discovery
set ether1 discover=yes
set bridge comment=defconf discover=yes
/queue interface
set bridge queue=no-queue
set [ find default=yes ] authentication-types="" eap-methods=passthrough \
    group-ciphers=aes-ccm group-key-update=5m interim-update=0s \
    management-protection=disabled mode=none mschapv2-username="" name=\
    default radius-eap-accounting=no radius-mac-accounting=no \
    radius-mac-authentication=no radius-mac-caching=disabled \
    radius-mac-format=XX:XX:XX:XX:XX:XX radius-mac-mode=as-username \
    static-algo-0=none static-algo-1=none static-algo-2=none static-algo-3=\
    none static-sta-private-algo=none static-transmit-key=key-0 \
    supplicant-identity=MikroTik tls-certificate=none tls-mode=\
    no-certificates unicast-ciphers=aes-ccm
    aes-ccm group-key-update=5m interim-update=0s management-protection=\
    allowed mode=dynamic-keys mschapv2-username="" name=profile1 \
    supplicant-identity="" tls-certificate=none tls-mode=no-certificates \
/interface wireless
set [ find default-name=wlan1 ] adaptive-noise-immunity=none allow-sharedkey=\
    no ampdu-priorities=0 amsdu-limit=8192 amsdu-threshold=8192 antenna-gain=\
    0 area="" arp=enabled band=2ghz-b/g/n basic-rates-a/g=6Mbps \
    basic-rates-b=1Mbps bridge-mode=enabled channel-width=20/40mhz-Ce \
    compression=no country=no_country_set default-ap-tx-limit=0 \
    default-authentication=yes default-client-tx-limit=0 default-forwarding=\
    yes dfs-mode=none disable-running-check=no disabled=no \
    disconnect-timeout=3s distance=dynamic frame-lifetime=0 frequency=2422 \
    frequency-mode=manual-txpower frequency-offset=0 guard-interval=any \
    hide-ssid=no ht-basic-mcs=mcs-0,mcs-1,mcs-2,mcs-3,mcs-4,mcs-5,mcs-6,mcs-7 \
    ht-supported-mcs="mcs-0,mcs-1,mcs-2,mcs-3,mcs-4,mcs-5,mcs-6,mcs-7,mcs-8,mc\
    s-9,mcs-10,mcs-11,mcs-12,mcs-13,mcs-14,mcs-15,mcs-16,mcs-17,mcs-18,mcs-19,\
    mcs-20,mcs-21,mcs-22,mcs-23" hw-fragmentation-threshold=disabled \
    hw-protection-mode=none hw-protection-threshold=0 hw-retries=7 \
    interworking-profile=disabled keepalive-frames=enabled mac-address=\
    6C:3B:6B:51:9E:65 max-station-count=2007 mode=station-bridge mtu=1500 \
    multicast-buffering=enabled multicast-helper=default name=wlan1 \
    noise-floor-threshold=default nv2-cell-radius=30 nv2-noise-floor-offset=\
    default nv2-qos=default nv2-queue-count=2 nv2-security=disabled \
    on-fail-retry-time=100ms preamble-mode=both proprietary-extensions=\
    post-2.9.25 radio-name=6C3B6B519E65 rate-selection=advanced rate-set=\
    default rx-chains=0 scan-list=default security-profile=profile1 ssid=\
    Archer_C20 station-bridge-clone-mac=00:00:00:00:00:00 \
    supported-rates-a/g=6Mbps,9Mbps,12Mbps,18Mbps,24Mbps,36Mbps,48Mbps,54Mbps \
    supported-rates-b=1Mbps,2Mbps,5.5Mbps,11Mbps tdma-period-size=2 \
    tx-chains=0 tx-power-mode=default update-stats-interval=disabled vlan-id=\
    1 vlan-mode=no-tag wds-cost-range=50-150 wds-default-bridge=none \
    wds-default-cost=100 wds-ignore-ssid=no wds-mode=disabled \
    wireless-protocol=any wmm-support=disabled
set [ find default-name=wlan2 ] adaptive-noise-immunity=none allow-sharedkey=\
    0 area="" arp=enabled band=2ghz-b/g basic-rates-a/g=6Mbps basic-rates-b=\
    1Mbps bridge-mode=enabled channel-width=20mhz compression=no country=\
    no_country_set default-ap-tx-limit=0 default-authentication=yes \
    default-client-tx-limit=0 default-forwarding=yes dfs-mode=none \
    disable-running-check=no disabled=no disconnect-timeout=3s distance=\
    dynamic frame-lifetime=0 frequency=2412 frequency-mode=manual-txpower \
    frequency-offset=0 guard-interval=any hide-ssid=no ht-basic-mcs=\
    mcs-0,mcs-1,mcs-2,mcs-3,mcs-4,mcs-5,mcs-6,mcs-7 ht-supported-mcs="mcs-0,mc\
    s-1,mcs-2,mcs-3,mcs-4,mcs-5,mcs-6,mcs-7,mcs-8,mcs-9,mcs-10,mcs-11,mcs-12,m\
    cs-13,mcs-14,mcs-15,mcs-16,mcs-17,mcs-18,mcs-19,mcs-20,mcs-21,mcs-22,mcs-2\
    3" hw-fragmentation-threshold=disabled hw-protection-mode=none \
    hw-protection-threshold=0 hw-retries=7 interworking-profile=disabled \
    keepalive-frames=enabled mac-address=4C:5E:0C:15:4F:30 max-station-count=\
    2007 mode=ap-bridge mtu=1500 multicast-buffering=enabled \
    multicast-helper=default name=wlan2 noise-floor-threshold=default \
    nv2-cell-radius=30 nv2-noise-floor-offset=default nv2-qos=default \
    nv2-queue-count=2 nv2-security=disabled on-fail-retry-time=100ms \
    preamble-mode=both proprietary-extensions=post-2.9.25 radio-name=\
    4C5E0C154F30 rate-selection=advanced rate-set=default rx-chains=0 \
    scan-list=default security-profile=default ssid=MikroTik \
    station-bridge-clone-mac=00:00:00:00:00:00 supported-rates-a/g=\
    6Mbps,9Mbps,12Mbps,18Mbps,24Mbps,36Mbps,48Mbps,54Mbps supported-rates-b=\
    1Mbps,2Mbps,5.5Mbps,11Mbps tdma-period-size=2 tx-chains=0 tx-power-mode=\
    default update-stats-interval=disabled vlan-id=1 vlan-mode=no-tag \
    wds-cost-range=50-150 wds-default-bridge=none wds-default-cost=100 \
    wds-ignore-ssid=no wds-mode=disabled wireless-protocol=any wmm-support=\
    disabled
/interface wireless manual-tx-power-table
set wlan1 manual-tx-powers="1Mbps:17,2Mbps:17,5.5Mbps:17,11Mbps:17,6Mbps:17,9M\
    bps:17,12Mbps:17,18Mbps:17,24Mbps:17,36Mbps:17,48Mbps:17,54Mbps:17,HT20-0:\
    17,HT20-1:17,HT20-2:17,HT20-3:17,HT20-4:17,HT20-5:17,HT20-6:17,HT20-7:17,H\
    T40-0:17,HT40-1:17,HT40-2:17,HT40-3:17,HT40-4:17,HT40-5:17,HT40-6:17,HT40-\
    7:17"
set wlan2 manual-tx-powers="1Mbps:17,2Mbps:17,5.5Mbps:17,11Mbps:17,6Mbps:17,9M\
    7:17"
/interface wireless nstreme
set wlan1 disable-csma=no enable-nstreme=no enable-polling=yes framer-limit=\
    3200 framer-policy=none
set wlan2 disable-csma=no enable-nstreme=no enable-polling=yes framer-limit=\
set wlan1 discover=yes
set wlan2 discover=yes
/ip dhcp-client option
set clientid code=61 name=clientid value="0x01\$(CLIENT_MAC)"
set hostname code=12 name=hostname value="\$(HOSTNAME)"
/ip hotspot profile
set [ find default=yes ] dns-name="" hotspot-address=0.0.0.0 html-directory=\
    hotspot html-directory-override="" http-cookie-lifetime=3d http-proxy=\
    0.0.0.0:0 login-by=cookie,http-chap name=default rate-limit="" \
    smtp-server=0.0.0.0 split-user-domain=no use-radius=no
/ip hotspot user profile
set [ find default=yes ] add-mac-cookie=yes address-list="" idle-timeout=none \
    !insert-queue-before keepalive-timeout=2m mac-cookie-timeout=3d name=\
    default !parent-queue !queue-type shared-users=1 status-autorefresh=1m \
    transparent-proxy=no
/ip ipsec mode-config
set (unknown) name=request-only send-dns=yes
/ip ipsec policy group
set default name=default
/ip ipsec proposal
set [ find default=yes ] auth-algorithms=sha1 disabled=no enc-algorithms=\
    aes-256-cbc,aes-192-cbc,aes-128-cbc lifetime=30m name=default pfs-group=\
    modp1024
/ppp profile
set *0 address-list="" !bridge !bridge-path-cost !bridge-port-priority \
    change-tcp-mss=yes !dns-server !idle-timeout !incoming-filter \
    !insert-queue-before !local-address name=default on-down="" on-up="" \
    only-one=default !outgoing-filter !parent-queue !queue-type !rate-limit \
    !remote-address !session-timeout use-compression=default use-encryption=\
    default use-mpls=default use-upnp=default !wins-server
set *FFFFFFFE address-list="" !bridge !bridge-path-cost !bridge-port-priority \
    !insert-queue-before !local-address name=default-encryption on-down="" \
    on-up="" only-one=default !outgoing-filter !parent-queue !queue-type \
    !rate-limit !remote-address !session-timeout use-compression=default \
    use-encryption=yes use-mpls=default use-upnp=default !wins-server
/queue type
set 0 kind=pfifo name=default pfifo-limit=50
set 1 kind=pfifo name=ethernet-default pfifo-limit=50
set 2 kind=sfq name=wireless-default sfq-allot=1514 sfq-perturb=5
set 3 kind=red name=synchronous-default red-avg-packet=1000 red-burst=20 \
    red-limit=60 red-max-threshold=50 red-min-threshold=10
set 4 kind=sfq name=hotspot-default sfq-allot=1514 sfq-perturb=5
set 5 kind=pcq name=pcq-upload-default pcq-burst-rate=0 pcq-burst-threshold=0 \
    pcq-burst-time=10s pcq-classifier=src-address pcq-dst-address-mask=32 \
    pcq-dst-address6-mask=128 pcq-limit=50KiB pcq-rate=0 \
    pcq-src-address-mask=32 pcq-src-address6-mask=128 pcq-total-limit=2000KiB
set 6 kind=pcq name=pcq-download-default pcq-burst-rate=0 \
    pcq-burst-threshold=0 pcq-burst-time=10s pcq-classifier=dst-address \
    pcq-dst-address-mask=32 pcq-dst-address6-mask=128 pcq-limit=50KiB \
    pcq-rate=0 pcq-src-address-mask=32 pcq-src-address6-mask=128 \
set 7 kind=none name=only-hardware-queue
set 8 kind=mq-pfifo mq-pfifo-limit=50 name=multi-queue-ethernet-default
set 9 kind=pfifo name=default-small pfifo-limit=10
/queue interface
set ether1 queue=only-hardware-queue
set wlan1 queue=wireless-default
set wlan2 queue=wireless-default
/routing bgp instance
set default as=65530 client-to-client-reflection=yes !cluster-id \
    !confederation disabled=no ignore-as-path-len=no name=default out-filter=\
    "" redistribute-connected=no redistribute-ospf=no redistribute-other-bgp=\
    no redistribute-rip=no redistribute-static=no router-id=0.0.0.0 \
    routing-table=""
/routing ospf instance
set [ find default=yes ] disabled=no distribute-default=never !domain-id \
    !domain-tag in-filter=ospf-in metric-bgp=auto metric-connected=20 \
    metric-default=1 metric-other-ospf=auto metric-rip=20 metric-static=20 \
    !mpls-te-area !mpls-te-router-id name=default out-filter=ospf-out \
    redistribute-bgp=no redistribute-connected=no redistribute-other-ospf=no \
    !routing-table !use-dn
/routing ospf area
set [ find default=yes ] area-id=0.0.0.0 disabled=no instance=default name=\
    backbone type=default
/snmp community
set [ find default=yes ] addresses=0.0.0.0/0 authentication-protocol=MD5 \
    encryption-protocol=DES name=public read-access=yes security=none \
    write-access=no
/system logging action
set 0 memory-lines=1000 memory-stop-on-full=no name=memory target=memory
set 1 disk-file-count=2 disk-file-name=log disk-lines-per-file=1000 \
    disk-stop-on-full=no name=disk target=disk
set 2 name=echo remember=yes target=echo
set 3 bsd-syslog=no name=remote remote=0.0.0.0 remote-port=514 src-address=\
    0.0.0.0 syslog-facility=daemon syslog-severity=auto syslog-time-format=\
    bsd-syslog target=remote
/user group
set read name=read policy="local,telnet,ssh,reboot,read,test,winbox,password,w\
    eb,sniff,sensitive,api,romon,!ftp,!write,!policy" skin=default
set write name=write policy="local,telnet,ssh,reboot,read,write,test,winbox,pa\
    ssword,web,sniff,sensitive,api,romon,!ftp,!policy" skin=default
set full name=full policy="local,telnet,ssh,ftp,reboot,read,write,policy,test,\
    winbox,password,web,sniff,sensitive,api,romon" skin=default
/caps-man aaa
set interim-update=disabled mac-caching=disabled mac-format=XX:XX:XX:XX:XX:XX \
/caps-man manager
set ca-certificate=none certificate=none enabled=no require-peer-certificate=\
    no
/certificate settings
set crl-download=yes
add auto-isolate=no bridge=bridge comment=defconf disabled=no edge=auto \
    external-fdb=auto horizon=none interface=ether1 path-cost=10 \
    point-to-point=auto priority=0x80
    external-fdb=auto horizon=none interface=wlan1 path-cost=10 \
add auto-isolate=no bridge=bridge disabled=no edge=auto external-fdb=auto \
    horizon=none interface=wlan2 path-cost=10 point-to-point=auto priority=\
    0x80
/interface bridge settings
set allow-fast-path=yes use-ip-firewall=no use-ip-firewall-for-pppoe=no \
    use-ip-firewall-for-vlan=no
set enabled=auto generic-timeout=10m icmp-timeout=10s tcp-close-timeout=10s \
    tcp-close-wait-timeout=10s tcp-established-timeout=1d \
    tcp-fin-wait-timeout=10s tcp-last-ack-timeout=10s \
    tcp-max-retrans-timeout=5m tcp-syn-received-timeout=5s \
    tcp-syn-sent-timeout=5s tcp-time-wait-timeout=10s tcp-unacked-timeout=5m \
    udp-stream-timeout=3m udp-timeout=10s
/ip neighbor discovery settings
set default=yes default-for-dynamic=no
/ip settings
set accept-redirects=no accept-source-route=no allow-fast-path=yes \
    arp-timeout=30s icmp-rate-limit=10 icmp-rate-mask=0x1818 ip-forward=yes \
    max-neighbor-entries=8192 route-cache=yes rp-filter=no secure-redirects=\
    yes send-redirects=yes tcp-syncookies=no
/interface l2tp-server server
set allow-fast-path=no authentication=pap,chap,mschap1,mschap2 \
    default-profile=default-encryption enabled=no keepalive-timeout=30 \
    max-mru=1450 max-mtu=1450 max-sessions=unlimited mrru=disabled use-ipsec=\
    no
/interface ovpn-server server
set auth=sha1,md5 cipher=blowfish128,aes128 default-profile=default enabled=\
    no keepalive-timeout=60 mac-address=FE:EF:4D:75:DD:90 max-mtu=1500 mode=\
    ip netmask=24 port=1194 require-client-certificate=no
/interface pptp-server server
set authentication=mschap1,mschap2 default-profile=default-encryption \
    enabled=no keepalive-timeout=30 max-mru=1450 max-mtu=1450 mrru=disabled
/interface sstp-server server
set authentication=pap,chap,mschap1,mschap2 certificate=none default-profile=\
    default enabled=no force-aes=no keepalive-timeout=60 max-mru=1500 \
    max-mtu=1500 mrru=disabled pfs=no port=443 tls-version=any \
    verify-client-certificate=no
/interface wireless align
set active-mode=yes audio-max=-20 audio-min=-100 audio-monitor=\
    00:00:00:00:00:00 filter-mac=00:00:00:00:00:00 frame-size=300 \
    frames-per-second=25 receive-all=no ssid-all=no
/interface wireless cap
set bridge=none caps-man-addresses="" caps-man-certificate-common-names="" \
    caps-man-names="" certificate=none discovery-interfaces="" enabled=no \
    interfaces="" lock-to-caps-man=no
/interface wireless sniffer
set channel-time=200ms file-limit=10 file-name="" memory-limit=10 \
    multiple-channels=no only-headers=no receive-errors=no streaming-enabled=\
    no streaming-max-rate=0 streaming-server=0.0.0.0
/interface wireless snooper
set channel-time=200ms multiple-channels=yes receive-errors=no
/ip accounting
set account-local-traffic=no enabled=no threshold=256
/ip accounting web-access
set accessible-via-web=no address=0.0.0.0/0
/ip cloud
set ddns-enabled=no update-time=yes
/ip cloud advanced
set use-local-address=no
/ip dhcp-client
add add-default-route=yes default-route-distance=0 dhcp-options=\
    hostname,clientid disabled=no interface=bridge use-peer-dns=yes \
    use-peer-ntp=yes
/ip dhcp-server config
set store-leases-disk=5m
set allow-remote-requests=no cache-max-ttl=1w cache-size=2048KiB \
    max-udp-packet-size=4096 query-server-timeout=2s query-total-timeout=10s \
    servers=""
/ip firewall service-port
set ftp disabled=no ports=21
set tftp disabled=no ports=69
set irc disabled=no ports=6667
set h323 disabled=no
set sip disabled=no ports=5060,5061 sip-direct-media=yes sip-timeout=1h
set pptp disabled=no
/ip hotspot service-port
/ip hotspot user
set [ find default=yes ] comment="counters and limits for trial users" \
    disabled=no name=default-trial
/ip ipsec policy
set 0 disabled=no dst-address=::/0 group=default proposal=default protocol=\
    all src-address=::/0 template=yes
/ip proxy
set always-from-cache=no anonymous=no cache-administrator=webmaster \
    cache-hit-dscp=4 cache-on-disk=no cache-path=web-proxy enabled=no \
    max-cache-object-size=2048KiB max-cache-size=unlimited \
    max-client-connections=600 max-fresh-time=3d max-server-connections=600 \
    parent-proxy=:: parent-proxy-port=0 port=8080 serialize-connections=no \
    src-address=::
/ip service
set telnet address="" disabled=no port=23
set ftp address="" disabled=no port=21
set www address="" disabled=no port=80
set ssh address="" disabled=no port=22
set www-ssl address="" certificate=none disabled=yes port=443
set api address="" disabled=no port=8728
set winbox address="" disabled=no port=8291
set api-ssl address="" certificate=none disabled=no port=8729
/ip smb
set allow-guests=yes comment=MikrotikSMB domain=MSHOME enabled=no interfaces=\
    all
/ip smb shares
set [ find default=yes ] comment="default share" directory=/pub disabled=no \
    max-sessions=10 name=pub
/ip smb users
set [ find default=yes ] disabled=no name=guest read-only=yes
/ip socks
set connection-idle-timeout=2m enabled=no max-connections=200 port=1080
/ip ssh
set always-allow-password-login=no forwarding-enabled=no strong-crypto=no
/ip traffic-flow
set active-flow-timeout=30m cache-entries=16k enabled=no \
    inactive-flow-timeout=15s interfaces=all
/ip upnp
set allow-disable-external-interface=no enabled=no show-dummy-rule=yes
/mpls
set dynamic-label-range=16-1048575 propagate-ttl=yes
/mpls interface
set [ find default=yes ] disabled=no interface=all mpls-mtu=1508
/mpls ldp
set distribute-for-default-route=no enabled=no hop-limit=255 loop-detect=no \
    lsr-id=0.0.0.0 path-vector-limit=255 transport-address=0.0.0.0 \
    use-explicit-null=no
/port firmware
set directory=firmware ignore-directip-modem=no
/ppp aaa
set accounting=yes interim-update=0s use-circuit-id-in-nas-port-id=no \
    use-radius=no
/radius incoming
set accept=no port=3799
/routing bfd interface
set [ find default=yes ] disabled=no interface=all interval=0.2s min-rx=0.2s \
    multiplier=5
/routing mme
set bidirectional-timeout=2 gateway-class=none gateway-keepalive=1m \
    gateway-selection=no-gateway origination-interval=5s preferred-gateway=\
    0.0.0.0 timeout=1m ttl=50
/routing rip
set distribute-default=never garbage-timer=2m metric-bgp=1 metric-connected=1 \
    metric-default=1 metric-ospf=1 metric-static=1 redistribute-bgp=no \
    redistribute-connected=no redistribute-ospf=no redistribute-static=no \
    routing-table=main timeout-timer=3m update-timer=30s
/snmp
set contact="" enabled=no engine-id="" location="" trap-community=public \
    trap-generators="" trap-target="" trap-version=1
/system clock
set time-zone-autodetect=yes time-zone-name=manual
/system clock manual
set dst-delta=+00:00 dst-end="jan/01/1970 00:00:00" dst-start=\
    "jan/01/1970 00:00:00" time-zone=+00:00
/system identity
set name=MikroTik
/system leds
set 0 disabled=no interface=wlan1 leds=led1,led2,led3,led4,led5 type=\
add disabled=no interface=wlan2 leds="wlan2_signal1-led,wlan2_signal2-led,wlan\
    2_signal3-led,wlan2_signal4-led,wlan2_signal5-led" type=\
add disabled=no interface=wlan2 leds=wlan2_tx-led type=interface-transmit
add disabled=no interface=wlan2 leds=wlan2_rx-led type=interface-receive
/system logging
set 0 action=memory disabled=no prefix="" topics=info
set 1 action=memory disabled=no prefix="" topics=error
set 2 action=memory disabled=no prefix="" topics=warning
set 3 action=echo disabled=no prefix="" topics=critical
/system note
set note="" show-at-login=yes
/system ntp client
set enabled=no server-dns-names=""
/system resource irq
set 0 cpu=auto
set 1 cpu=auto
set 2 cpu=auto
set 3 cpu=auto
set 4 cpu=auto
set boot-device=nand-if-fail-then-ethernet boot-protocol=bootp cpu-frequency=\
    600MHz force-backup-booter=no init-delay=0s protected-routerboot=disabled \
    silent-boot=no
/system routerboard usb
set type=USB-type-A
/system upgrade mirror
set check-interval=1d enabled=no primary-server=0.0.0.0 secondary-server=\
    0.0.0.0 user=""
/system watchdog
set auto-send-supout=no automatic-supout=yes no-ping-delay=5m watch-address=\
    none watchdog-timer=yes
/tool bandwidth-server
set allocate-udp-ports-from=2000 authenticate=yes enabled=yes max-sessions=\
    100
/tool e-mail
set address=0.0.0.0 from=<> port=25 start-tls=no user=""
/tool graphing
set page-refresh=300 store-every=5min
/tool mac-server
/tool mac-server mac-winbox
/tool mac-server ping
set enabled=yes
/tool romon
set enabled=no id=00:00:00:00:00:00 secrets=""
/tool romon port
set [ find default=yes ] cost=100 disabled=no forbid=no interface=all \
    secrets=""
/tool sms
set allowed-number="" channel=0 keep-max-sms=0 receive-enabled=no
/tool sniffer
set file-limit=1000KiB file-name="" filter-cpu="" filter-direction=any \
    filter-interface="" filter-ip-address="" filter-ip-protocol="" \
    filter-ipv6-address="" filter-mac-address="" filter-mac-protocol="" \
    filter-operator-between-entries=or filter-port="" filter-stream=no \
    memory-limit=100KiB memory-scroll=yes only-headers=no streaming-enabled=\
    no streaming-server=0.0.0.0
/tool traffic-generator
set latency-distribution-max=100us measure-out-of-order=yes \
    stats-samples-to-keep=100 test-id=0
/user aaa
set accounting=yes default-group=read exclude-groups="" interim-update=0s \
    use-radius=no
https://wiki.mikrotik.com/wiki/Manual:Wireless_Station_Modes
Sure you have read it…
It really can be the reason that the ap is not a mikrotik device because standard WiFi implementation does not provide bridging functionality. Think about changing the ap to mikrotik or about running masquerade nat at the client wlan of your repeater (home gateway mode with wlan1 as wan interface). Or to run wire…
Thanks for help.
I’m completely a newbie to mikrotik. Changing ap is not an option, running wire also. I tried to make masquerade but with no result, probably did it wrong.
So, anything is possible, excluding wire running and equipment change. Goal is one: “make the Internet work again” ~ Every customer
