Hello everybody. I would have a question. Can damage the AP if we use 1 and 2 chains client simultaneously ?
Sure both of the chains enabled in the AP.
Thank you in advanced.
Do you mean the ap has 2 chains enabled with a dual chain antenna and then you connect a mixture of cpe’s to it sxt(2chain) rb groove(1 chain) ?
Is so then it won’t be a problem
Yes, exactly i mean this way, thank you anyway.
