2 different interface with 2 subnet : make them talk...
My problem seems simple, if anyone could help there please :slight_smile:
I have an interface ETH2 with address 192.168.141.254 on a /24 subnet and a ETH3 with address 192.168.142.254 on a /24
Both have dhcp etc.
I can’t make a computer from the 141 subnet ping one from the 142 and same the other way.
Could you please help about that little problem, if you have a clean solution to make that work ?
Regards
Andy
It should happen by default.
A device from the .141.0 network will look for the other on the .142.0 network. Since it can not find it within it’s own network, will ask the router about it. The router on the other hand will know where the other device is, will discover it and establish connection. This because both networks are connected to the router and create the connected routes automatically. Unless there is some firewall filter rules or routing policy preventing this to happen, they should connect.
Should be work by default may be their is problem with settings please share router settings here
Is DHCP giving default gateway address?
Here is the configuration
jan/02/2002 06:47:40 by RouterOS 6.3
software id = 9LFB-WFVQ
add admin-mac=D4:CA:6D:E6:24:A7 auto-mac=no l2mtu=1598 name=bridge-local
protocol-mode=rstp
add name=bridge-local-2
set 0 name=ether1-gateway
set 3 disabled=yes
set 4 disabled=yes
set 5 disabled=yes name=ether6-master-local
set 6 disabled=yes name=ether7-slave-local
set 7 disabled=yes name=ether8-slave-local
set 8 disabled=yes name=ether9-slave-local
set 9 disabled=yes name=ether10-slave-local
set 10 name=sfp1-gateway
/interface pppoe-client
add add-default-route=yes comment="ADSL DIRECTION" disabled=no interface=
ether1-gateway name=pppoe-out-DIRECTION password=XXXXX service-name=ADSL
user=XXXXXX
/ip neighbor discovery
set ether1-gateway discover=no
set sfp1-gateway discover=no
set pppoe-out-DIRECTION comment="ADSL DIRECTION"
/ip hotspot user profile
set [ find default=yes ] idle-timeout=none keepalive-timeout=2m
mac-cookie-timeout=3d
/ip ipsec proposal
set [ find default=yes ] auth-algorithms=md5,sha1 enc-algorithms=
3des,aes-128,aes-192,aes-256,blowfish
add name=pool-141 ranges=192.168.141.100-192.168.141.200
add name=pool-142 ranges=192.168.142.100-192.168.142.200
add address-pool=pool-141 disabled=no interface=bridge-local name=dhcp-141
add address-pool=pool-142 disabled=no interface=bridge-local-2 name=dhcp-142
/port
set 0 name=serial0
/ppp profile
add dns-server=192.168.141.254 local-address=10.0.0.141 name=profile-vpn-pptp
add dns-server=192.168.141.254 local-address=10.1.0.141 name=
profile-vpn-mnt-pptp
/system logging action
set 0 memory-lines=100
set 1 disk-lines-per-file=100
add bridge=bridge-local interface=ether2
add bridge=bridge-local-2 interface=ether3
set 6 default-vlan-id=0
set 7 default-vlan-id=0
set 8 default-vlan-id=0
set 9 default-vlan-id=0
set 10 default-vlan-id=0
set 12 default-vlan-id=0
/interface pptp-server server
set enabled=yes
add address=192.168.141.254/24 comment="default configuration" interface=
bridge-local network=192.168.141.0
add address=192.168.142.254/24 comment="default configuration" interface=
bridge-local-2 network=192.168.142.0
/ip dhcp-client
add comment="default configuration" dhcp-options=hostname,clientid disabled=
no interface=sfp1-gateway
no interface=ether1-gateway
add address=192.168.141.0/24 comment="default configuration" dns-server=
192.168.141.5,192.168.141.254 gateway=192.168.141.254 netmask=24
ntp-server=192.168.141.254
add address=192.168.142.0/24 comment="default configuration" dns-server=
192.168.142.254 gateway=192.168.142.254 netmask=24 ntp-server=
192.168.142.254
set allow-remote-requests=yes servers=117.20.32.54,117.20.32.84
add chain=input comment="default configuration" protocol=icmp
add chain=input comment="default configuration" connection-state=established
add chain=input comment="default configuration" connection-state=related
add action=drop chain=input comment="default configuration" in-interface=
sfp1-gateway
ether1-gateway
add chain=forward comment="default configuration" connection-state=
established
add chain=forward comment="default configuration" connection-state=related
add action=drop chain=forward comment="default configuration"
connection-state=invalid
add action=masquerade chain=srcnat comment="default configuration"
out-interface=ether1-gateway to-addresses=0.0.0.0
out-interface=sfp1-gateway
out-interface=pppoe-out-DIRECTION to-addresses=0.0.0.0
add chain=srcnat comment="NAT TUNNEL DAFE" dst-address=161.48.0.0/16
src-address=192.168.142.0/24
add chain=srcnat dst-address=10.200.0.0/13 src-address=192.168.142.0/24
add chain=srcnat dst-address=86.66.22.0/24 src-address=192.168.142.0/24
/ip ipsec peer
add address=86.66.23.2/32 dpd-interval=disable-dpd enc-algorithm=aes-128
hash-algorithm=sha1 secret=XXXXXX
/ip ipsec policy
add dst-address=10.200.0.0/13 sa-dst-address=86.66.23.2 sa-src-address=
117.20.37.121 src-address=192.168.142.0/24 tunnel=yes
add dst-address=86.66.22.0/24 sa-dst-address=86.66.23.2 sa-src-address=
add dst-address=161.48.0.0/16 sa-dst-address=86.66.23.2 sa-src-address=
/lcd interface
set sfp1-gateway interface=sfp1-gateway
set ether1-gateway interface=ether1-gateway
set ether2 interface=ether2
set ether3 interface=ether3
set ether4 interface=ether4
set ether5 interface=ether5
set ether6-master-local interface=ether6-master-local
set ether7-slave-local interface=ether7-slave-local
set ether8-slave-local interface=ether8-slave-local
set ether9-slave-local interface=ether9-slave-local
set ether10-slave-local interface=ether10-slave-local
/system clock
set time-zone-name=Pacific/Wallis
/system identity
set name=MKT-DIRECTION
/system ntp client
set enabled=yes primary-ntp=202.22.232.241 secondary-ntp=119.148.67.183
/system ntp server
set enabled=yes
/tool graphing interface
add
/tool graphing queue
add
/tool graphing resource
add
/tool mac-server
add interface=ether2
add interface=ether3
add interface=ether4
add interface=ether5
add interface=ether6-master-local
add interface=ether7-slave-local
add interface=ether8-slave-local
add interface=ether9-slave-local
add interface=bridge-local
/tool mac-server mac-winbox
A couple of things. If I am reading correctly you have disabled all your ethernet ports except the ether1, right?
Why use bridge when under the bridge you have encapsulated only one interface? Bridge is meant to .. bridge two or more interfaces.
And in your post I don’t see /ip route configuration?
The only interface up are the 1 2 and 3
I m putting them in the bridge, cause for the moment, i m only using those 3, but in a near future, i will add more port to those bridge :slight_smile:
And you can't see the route configuration for a simple reason, they are all dynamics.
DST-ADDRESS PREF-SRC GATEWAY DISTANCE
0 ADC 192.168.141.0/24 192.168.141.254 bridge-local 0
1 ADC 192.168.142.0/24 192.168.142.254 bridge-local-2 0
Thanks a lot for your quick answer, feel free to ask any question, i will answer them right now to try to fix my problem
Regards
Andy
How are the clients connected to your router? Are they served by dhcp?
From your router, can you ping the clients?
The client on port 2 get the 141 dhcp as you can see in the config, and those on the 3 get the 142.
Everyone on the same subnet can talk to each other, there is no problem about that.
what i meant is if you can ping computers from both networks from your router, to be sure that the router can actually reach them. Also, these computers will discover each other by IP and not by using Microsft Discovery for example since they are not on the same broadcast domain.
in the masquerade rule I would go with only one rule just for testing:
add action=masquerade chain=srcnat comment="default configuration" \
notice, without the to-addresses=0.0.0.0
I don’t think it’s a solution.
Mascarading the pppoe-direction isn’t supposed to do anything but give this to all my bridge/interface right ?
My pppoe is not even connected at the moment, and i don’t see why i would need it to go from ETH2 to ETH3 ?
Can you please explain that ? cuase i m not sure i understand why you would do that ?
THanks
Andy
ps: tried it, didn’t work
do you have a working conf like that i could try to import on my router to see if it works?
I need to have two subnet, one on each interface (with dhcp) that can talk together : / i m trying to find what is wrong, but can’t see what : /
add admin-mac=D4:CA:6D:E6:24:A7 auto-mac=no l2mtu=1598 name=bridge-local \
protocol-mode=rstp
brother i think your bridge configuration not correct btw why you are using rstp protocol and ARP setting also missing please add simple bridge with no protocol and admin mac address and test your setting working or not then do further settings on it
I would go like this. Make a backup of the current configuration, and reset router with no defaults.
Then put a simple config, with IP for the two ethernets, one for the gateway, one masquerade rule and see what happens.
Pretty sure that both networks should connect to each other using the router. Test it with a simple configuration.
I’ll try that and tell you what happens.
Thanks a lot guys
PS : the bridge configuration is the one by default
Ok, so, i just tried, total reset of the router, no configuration, just configured the dhcp, adresses on the interfaces i needed, and the basic default firewall rules the mikrotik add + one that clearly specify that from 141 you can talk to 142 etc.
Tell me where it's wrong... : / can't solve that supposed simple problem : / if someone has a working conf of something like that i would love to see it
Thanks a lot guys
jan/02/1970 00:12:36 by RouterOS 6.3
add address-pool=pool-141 disabled=no interface=ether2 name=dhcp-141
add address-pool=pool-142 disabled=no interface=ether3 name=dhcp-142
/port
set 0 name=serial0
add address=192.168.141.254/24 interface=ether2 network=192.168.141.0
add address=192.168.142.254/24 interface=ether3 network=192.168.142.0
add address=192.168.141.0/24 dns-server=192.168.141.254 gateway=
192.168.141.254 ntp-server=192.168.141.254
add address=192.168.142.0/24 dns-server=192.168.142.254 gateway=
192.168.142.254 ntp-server=192.168.142.254
sfp1-gateway
ether1-gateway
established
add chain=forward comment="permit access between subnets" connection-state=
new dst-address=192.168.142.0/24 src-address=192.168.141.0/24
new dst-address=192.168.141.0/24 src-address=192.168.142.0/24
/lcd interface
set ether6 interface=ether6
set ether7 interface=ether7
set ether8 interface=ether8
set ether9 interface=ether9
set ether10 interface=ether10
I would start with no firewall filters at all.
Then, is DHCP working?
Is there a firewall on the connected systems that can hold traffic ?
Brother if you are still facing problem my advice to you is do configuration manually from scratch mean don’t wile resetting router don’t use default configuration then configure interfaces without bridging and check if works then create bridge and check just go thru troubleshooting way step by step
It is not that it requires any specific configuration, it is just straight forward, it should work by default. That is all a router is about, connect networks attached to it.
How are you testing if the computers or devices are communicating with each other? Do you have anything in firewall mangle rule?
Nothing at all, i even started from scratch and it’s not working, that’s why i m asking if anyone could provide a working conf to try to understand where the problem is
I even tried to reset the router, put an address on an interface, another one on the second one. Put my two computer in static ip, and remove all firewall, and it doesn’t work.
If anyone could try on his side i would love it.
Thanks a lot
If you want my skype contact is enova-andy
Regards
Andy
brother when you assign ip address to interfaces router creates default routes automatically for talking to each other in /ip route and second thing i would love to give you config but right now i did not have spare router to make configuration as per your requirement btw are you using winbox or terminal to configure router?
