2 gateway problems
Hi
On one of the routers i have 2 internet connections:
public_1: lets say 172.16.0.1 Wan1
public_2 172.17.0.1 Wan2
And i have 2 private subnets 192.168.1.0/24 on Lan1 interface and 10.10.10.0/24 on Lan2 interface
What i want is to have 192.168.1.0/24 route out through 172.16.0.1 (basically this to be the default connection and the other 1 to be used only for 10.10.10.0/24)
and 10.10.10.0/24 to route out through 172.17.0.1
I have tried a lot of examples related to multiple gateways but none worked for me for some reason
I don’t need load balancing, i just 1 subnet to go out through 1 connection and the other one through the other connection
If anyone can give me a clue on how to do this
Thank you
you have to mask traffic from subnet A to go to gateway a and subnet B to go to route b
you have to add default gw, then add default gw with routing mark a to go to a and same for B and gw b
then in mangle mark routing accordingly. You have to have default gw without routing mark.
