2 gateways for different LAN
please help with this problem.
I have 2 routes set for gateways:
add distance=1 gateway=192.168.1.1
add distance=1 gateway=192.168.1.2 routing-mark=2nd_ISP
/ip firewall mangle
add action=mark-routing chain=prerouting in-interface="Bridge HOTSPOT" new-routing-mark=2nd_ISP
add address=192.168.77.1/24 interface="Bridge HOTSPOT" network=192.168.77.0
add address=192.168.1.7/24 interface="Bridge PRIVATE" network=192.168.1.0
/ip route print
Flags: X - disabled, A - active, D - dynamic, C - connect, S - static, r - rip, b - bgp, o - ospf, m - mme, B - blackhole, U - unreachable, P - prohibit
 0 A S  0.0.0.0/0                          192.168.1.1               1
 1   S  0.0.0.0/0                          192.168.1.2               1
 2 ADC  192.168.1.0/24     192.168.1.7     Bridge PRIVATE            0
 3 ADC  192.168.77.0/24    192.168.77.1    Bridge HOTSPOT            0
The problem is, that route for 2nd ISP stays inactive (blue).
Where is the problem?
Thank you
There is a strange wa how to fix it.
If I change the routing mark at route and firewall mangle to different name, the route starts to work.
If I restart the mikrotik, the route stops working (turns blue) and I have to change mark to different name…
Wierd…
you cant have 2 default routes .
what you can do is packet mangling and changing the gateway address based on a policy
this is commonly refered to “policy based routing”
Will you please help me with correct setup?
Thank you a lot - I am novice…
