i wanna ask if it would be possible to setup two internet connections where one is for inbound traffic and one for outbound traffic.
Or a little bit clearer, i have to setup a mikrotik router (router B) behind another router (router A). And i can’t configure any portforwardings or something on router A, so no inbound traffic is possible.
Now i wanna use a umts-modem for incoming ipsec/lt2p traffic behind router B.
i think i found the solution, there was a description in the forum, so i followed that and configured that on my RB2011.
Currently it look it works correctly, all Connections from the local LAN goes trough WAN1 where is the router without ability to setup any portforwarding.
And if i connect a second laptop on WAN2 i can connect to the router trough IPSec/L2TP.
