Hello. First of all, I’m Brazilian, sorry for my poor English.
I need to configure a network with the following characteristics: 2 internet links (PPPoE) and two networks (LAN1: 192.168.10.0/24 and LAN2: 192.168.0.254/24).
Each network has its own Internet link (LAN1 uses LINK1 and LAN2 uses LINK2). This part I already did using package marking and specific routes for each package mark.
Now, I need to configure it so that when one Internet link down, the other link assumes both networks.
For example:
- LINK1 down → LAN1 and LAN2 will use LINK2;
- LINK2 down → LAN1 and LAN2 will use LINK1;
- link returned → LAN1 resumes using LINK1 and LAN2 resumes using LINK2.
I thank you all.
Thanks for answering.
In the example above, there is only one local network. In my case there are two. This is precisely my greatest difficulty.
I can not make an internet take over the two networks when the other one falls.
I think I’ll need to do a script to monitor the two internet links.
I do this configuration on Linux, but on Mikrotik I do not know how to do it.
Can anybody help me?
Thank you.
Hi
Within the existing routing table, as designated by the routing-mark, just add additonal default route going to the other isp, BUT with higher distance.
If first becomes invalid, second will be picked up.
Hi sebastia.
It worked!
I was trying to complicate a simple problem to solve.
Thank you very much.
