hello guys new here and just learning this routerOS, anyone can direct me to a guide how to set this up, i have 2 isp one is good for gaming but slow and one is good for everything else
isp1 = router is on 192.168.50.0/24 gateway is 192.168.50.1 (good for everything else)
Isp2 = router is on 192.168.100.0/24 gateway is 192.168.100.1 (good for gaming)
is thier a way to forward everything to isp1 and just use isp2 for certain game like cod warzone base on tcp and udp ports?
i would like to just use isp2 for selected games that doesnt work well with isp1 that i can add manually
i dont need load balance or fail over, and i dont think i need firewall because each isp modem is connected to a router already with firewall, right now what i do is just plug to which router i want to use and i think this mikrotik router can automate it for me , and my 2 routers i would like to use local static ip because i turn dchp on the isp2 router so i can plug it in the same network as isp1 and just change ip to use which one i want to use
thanks in advance
