Two ISP in and one LAN out. LAN all user to use both ISP line
How can it possible. By using winbox .
Pls help me
Pls help me
pls everybody help me. another way to solve this problem…
many thanks…“HILTON” Brother
rootpoint: did you get that work? its seems look like what i need…
what if i use 2 ADSL connection, 1-st is with static IP address and 2-nd is with dynamic IP address does that way works? if yes can you tell me how?
please help me pleople
PCC is independent of the way each interface connects to internet.
You just need to configure a static address on one interface and a dhcp-client on another.
