Greetings all..
Got a little problem that I have been tinkering around with.
I have 1 RB750 of which dials 2 seperate PPPoE DSL lines now the mission is to have 192.168.20.0 go out via PPPoE-1 and the 192.168.30.0 go out via PPPoE-2 (both for internet access).
At this moment I have created 2 bridges; bridge1: Ether 3, Wlan1 // and bridge2: ether2, Wlan2(Virtual AP) so bridge 1 will use PPPoE-1 and bridge 2 will use PPPoE-2
I have followed guides and have done this so far
1 chain=srcnat action=masquerade out-interface=PPPoE1
/ip firewall mangle
0 chain=prerouting action=mark-connection new-connection-mark=ISP1_conn
passthrough=yes src-address=192.168.20.0/24
1 chain=output action=mark-routing new-routing-mark=to_ISP1 passthrough=yes
src-address=192.168.20.0/24 connection-mark=ISP1_conn
I have added this to the routes
0 add gateway=PPPoE1 routing-mark=to_ISP1
I have swapped the Output chain with prerouting to test and unfortunitly I cannot connect to the internet, I seem to be able to Ping 8.8.8.8
Guides I have seen
- http://forum.mikrotik.com/t/dual-wan-connection-marks-only-when-using-mangle-input/70893/1
http://forum.mikrotik.com/t/3-wan-via-pppoe-to-3-internal-networks/69826/1
Thanks for the help ladies & gents
