2 ISP-s (gateways,IPs) for one Mikrotik routed network ???
Hi!
I have one ISP and they gave me one public ip and default gateway…
but now i have one more ISP for test only…
how can i use both of them???
in this situation i will have 2 public ip’s and 2 dafault gateways…
i have 70 wireless hotspot users on 10.5.50.0/24 prism interface and this network is masqueraded to first ISP ip (80.74.XXX.XX)
how can i use both ISP??? can i have 2 public IPs and 2 DEFAULT GATEWAYS..
only to make something clear: both ISP-s will come via one ethernet cable (i will recieve them over one ethernet NIC)
i know its sounds strange but its true! :slight_smile:
please help
The simpliest way is to “split” your users to two groups and then use routing tables to tell each user/group what gateway/isp to use. The solution with entering two gateways to complete lan is not working well…
Tnx
ili HVALA !!!
poz
Slobo
I have 2 gateways as well.
You just have to make a new route dst-adr=0.0.0.0/0 gateway=1st ISP, 2nd ISP
ili na srpskom ja imam dva izlaza koja se natuju. Stavis default rutu na oba i radi super
Pozdrav Djole
odlicno, probacu i to…
Hvala na pomoci!
Au, sta je ovde ljudi sa naseg govornog podrucja :smiley:
A sada malo na engleskom
I have tryed to use two gateways, but packets get lost somewhere. I had a lot of packetlosses with that solution so have to use two diferent gateways.
Gde ima nesto jeftino a dobro tu su i Srbi. Imam malu ispravku na moj prosli post umesto reci nat treba da stoji masquarade.
In my last post there was a mistake. Instead of nat should be masquarade.
All the best, Djole
Sta mislite o tome da napravimo neko mestasce gde bi smo mogli da pricamo na srpskom?
please use english on the forum, so that others also can understand your conversation :slight_smile:
HHi hhee
Pa mogli bih da naparvimo jedan POST " MIKROTIKOVCI " i da spikamao na srpskom :slight_smile:)))
