Hi there,
I opened another topic but I think that I wasn’t explicit enough so I will be now because I need help to figure it out how to use two ISP with 2 public subnets (IPv4) on a Mikrotik CHR Router.
So we have the following schema:
- CHR with 4 virtual ports (ether1, ether2, ether3, ether4)
- ISP1 provides a /29 IPv4 subnet on port ether1 that’s routed via 1.1.1.1.
- ISP2 provides a /27 IPv4 subnet on port ether4 that is routed via 2.2.2.2.
- Ether2 and ether 3 are used for LAN.
I have DHCP server setup on bridge for LAN2 and LAN3 with LAN class 10.0.0.0/8.
L.E.: Default 0.0.0.0/0 route it’s going through port ether1 (1.1.1.1). So when I add a new 0.0.0.0/0 I need to specify a Routing Mark rule in order to be able to use it too.
How do I make to use both ISP1 and ISP2 simultaneously on the same LAN class (10.0.0.0/8), without Load Balancing or Failover?
I tried to follow some tutorials from this forum but without success. What Mangle firewall rules should I create?
