So I have two seperate LAN, 192.168.1.0/24 (lan1) and 192.168.2.0/24 (lan2). I also have two gateway (internet) on port1 and port2 of the RB951.
I want to make all lan1 have a gateway to port1 and all lan2 have a gateway to port2?
How can I approach this?
http://wiki.mikrotik.com/wiki/Load_Balancing_over_Multiple_Gateways
Send from my mobile phone using Tapatalk.
That is exactly what I followed before posting here. Almost the same setup, only difference on mine is lan1 is from the lan ports (3-5 interface) and lan2 is the wlan1 interface.
But fail, is that tutorial even working or I need to add more config that is not mentioned on the tutorial??
Post your export so we can have a look.
And since you seem to have 2 /24 segments, you should have 2 NAT masquerade rules.
You can do this simply using Routing Rules
In winbox go to IP Routes
Add default routes with routing marks eg wan1 and wan2, specify the gateway on each one.
then go to the Rules tab
Then add rules for each subnet, using the src address of the lan, action of lookup and table specifies the routing mark.
Hope that helps
Nick.
Rudios, I am aware of that, thanks for the reminder. Here is my export:
#lan1 is 192.168.14.0/24 network
#wifi network is 192.168.15.0/24
#wan1 gateway is 192.168.20.1
#wan2 gateway is 192.168.46.1
Basically I want all wifi to pass on wan2, and I want all lan1 to pass on wan1
set [ find default-name=ether1 ] name=port1
set [ find default-name=ether2 ] name=port2
set [ find default-name=ether3 ] name=port3
set [ find default-name=ether4 ] master-port=port3 name=port4
set [ find default-name=ether5 ] master-port=port3 name=port5
/interface wireless
set [ find default-name=wlan1 ] default-ap-tx-limit=1024000 disabled=no l2mtu=2290 mode=ap-bridge
/ip hotspot user profile
set [ find default=yes ] idle-timeout=none keepalive-timeout=2m mac-cookie-timeout=3d
add name=dhcp_pool1 ranges=192.168.15.50-192.168.15.200
add address-pool=dhcp_pool1 disabled=no interface=wlan1 lease-time=6h name=server1
add address=192.168.15.1/24 comment=wifi interface=wlan1 network=192.168.15.0
add address=192.168.46.100/24 comment=wan2 interface=port2 network=192.168.46.0
add address=192.168.20.100/24 comment=wan1 interface=port1 network=192.168.20.0
add address=192.168.14.100/24 comment=lan interface=port3 network=192.168.14.0
add address=192.168.15.0/24 dns-server=208.67.222.222,208.67.220.220 gateway=192.168.15.1 netmask=24
set allow-remote-requests=yes servers=208.67.222.222,208.67.220.220
/ip firewall mangle
add action=mark-routing chain=prerouting comment=lan-to-wan1 new-routing-mark=to_wan1 passthrough=no src-address=192.168.14.0/24
add action=mark-routing chain=prerouting comment=wifi_to_wan2 new-routing-mark=to_wan2 passthrough=no src-address=192.168.15.0/24
add action=masquerade chain=srcnat src-address=192.168.14.0/24
add action=masquerade chain=srcnat src-address=192.168.15.0/24
add distance=1 gateway=192.168.20.1 routing-mark=to_wan1
add distance=1 gateway=192.168.46.1 routing-mark=to_wan2
/system leds
set 0 interface=wlan1
nickshore, I’m new to routing rules, can you elaborate more?
Do you mean this? http://blog.butchevans.com/2008/09/mikrotik-policy-routing-implementation-example/
I can’t make it work either.
OK, I think I made some progress, instead of just src-address in the mangle rules, I made it src-address-list and then added firewall address-list.
/ip firewall address-list
add address=192.168.14.0/24 list=lan-users
add address=192.168.15.0/24 list=wifi-users
/ip firewall mangle
add action=mark-routing chain=prerouting comment=lan-to-wan1 new-routing-mark=to_wan1 passthrough=no src-address-list=lan-users
add action=mark-routing chain=prerouting comment=wifi_to_wan2 new-routing-mark=to_wan2 passthrough=no src-address-list=wifi-users
ping from lan1 goes to wan1 and ping from wifi goes to wan2.
It seems to be working, (but I needed more tests), and is this really the traceroute that I should expect?
D:\Documents and Settings\Administrator>tracert 8.8.8.8
Tracing route to 8.8.8.8 over a maximum of 30 hops
1 4294967294 ms 4294967294 ms 4294967294 ms 192.168.14.100
2 1 ms 4294967294 ms 4294967294 ms 192.168.20.1
3 78 ms 76 ms 76 ms 10.198.140.89
4 467 ms 66 ms 96 ms 10.198.140.90
