Hi guys, I am very new to Mikrotik. I have some problem. I have 2 LAN and 2 WAN as picture below:
As you can see LAN 1 will use WAN 1 and LAN 2 will use WAN 2. But I cant connect between these 2 LANs. Here is my configuration:
/ip firewall mangle
add action=mark-connection chain=prerouting disabled=no new-connection-mark=wan1 passthrough=yes src-address=192.168.0.0/24
add action=mark-routing chain=prerouting connection-mark=wan1 disabled=no new-routing-mark=wan1 passthrough=yes src-address=192.168.0.0/24
add action=mark-connection chain=prerouting disabled=no new-connection-mark=wan2 passthrough=yes src-address=192.168.1.0/24
add action=mark-routing chain=prerouting connection-mark=wan2 disabled=no new-routing-mark=wan2 passthrough=yes src-address=192.168.1.0/24
add action=masquerade chain=srcnat disabled=no src-address=192.168.0.0/24
add action=masquerade chain=srcnat disabled=no src-address=192.168.1.0/24
add disabled=no distance=1 dst-address=0.0.0.0/0 gateway=10.10.10.1 routing-mark=wan1 scope=30 target-scope=10
add disabled=no distance=1 dst-address=0.0.0.0/0 gateway=10.1.1.1 routing-mark=wan2 scope=30 target-scope=10
add disabled=no distance=1 dst-address=0.0.0.0/0 gateway=10.10.10.1 scope=30 target-scope=1
What should I do to connect between these 2 LAN. Your thought and advise is highly appreciated. Thank you!
