vlan99 in mngmt - when i try to send it by secondary link i get loop. Even when vlan99 is not on sw2 port eth19. This is 1st step in my mind.
vlan1233 and vlan1234 is dummy - not used anywhere - just to avoid loops.
SW1
add frame-types=admit-only-vlan-tagged name=bridge1 protocol-mode=none vlan-filtering=yes
set [ find default-name=ether1 ]
set [ find default-name=ether2 ]
set [ find default-name=ether3 ]
set [ find default-name=ether4 ] disabled=yes poe-out=off speed=10Mbps
set [ find default-name=ether5 ]
set [ find default-name=ether6 ]
set [ find default-name=ether7 ]
set [ find default-name=ether8 ]
set [ find default-name=ether9 ]
set [ find default-name=ether10 ]
set [ find default-name=ether12 ]
set [ find default-name=ether13 ]
set [ find default-name=ether14 ]
set [ find default-name=ether15 ]
set [ find default-name=ether16 ] poe-out=off
set [ find default-name=ether17 ] poe-out=off poe-voltage=high
set [ find default-name=sfp-sfpplus1 ]
set [ find default-name=sfp-sfpplus2 ]
set [ find default-name=sfp-sfpplus3 ]
set [ find default-name=sfp-sfpplus4 ]
/interface vlan
add interface=bridge1 name=managment vlan-id=99
/ip hotspot profile
/user group
set full policy=local,telnet,ssh,ftp,reboot,read,write,policy,test,winbox,password,web,sniff,sensitive,api,romon,dude,tikapp
add bridge=bridge1 interface=ether1 pvid=22
add bridge=bridge1 interface=ether2 pvid=23
add bridge=bridge1 interface=ether3 pvid=24
add bridge=bridge1 interface=ether5 pvid=27
add bridge=bridge1 interface=ether6 pvid=40
add bridge=bridge1 interface=ether7 pvid=39
add bridge=bridge1 interface=ether8 pvid=38
add bridge=bridge1 interface=ether9 pvid=14
add bridge=bridge1 interface=ether10 pvid=1234
add bridge=bridge1 interface=sfp-sfpplus1
add bridge=bridge1 interface=ether11
add bridge=bridge1 interface=ether12 pvid=27
add bridge=bridge1 interface=ether13 pvid=98
add bridge=bridge1 interface=ether14 pvid=1233
add bridge=bridge1 interface=ether15 pvid=98
add bridge=bridge1 frame-types=admit-only-vlan-tagged interface=sfp-sfpplus2
add bridge=bridge1 interface=sfp-sfpplus3
add bridge=bridge1 interface=sfp-sfpplus4
set discover-interface-list=all
/interface bridge vlan
add bridge=bridge1 tagged=“ether1,ether2,ether3,ether4,ether5,ether6,ether7,ether8,ether9,ether11,ether12,ether13,ether14,ether1
5,ether16,ether17,ether18,ether19,ether20,ether21,ether22,ether23,ether24,sfp-sfpplus1,sfp-sfpplus2,sfp-sfpplus3,sfp-sfpplus
4,bridge1” vlan-ids=99
add bridge=bridge1 tagged=sfp-sfpplus1,sfp-sfpplus2 untagged=ether1 vlan-ids=22
add bridge=bridge1 tagged=sfp-sfpplus1,sfp-sfpplus2 untagged=ether2 vlan-ids=23
add bridge=bridge1 tagged=sfp-sfpplus1,sfp-sfpplus2 untagged=ether3 vlan-ids=24
add bridge=bridge1 tagged=sfp-sfpplus1,sfp-sfpplus2 untagged=ether4,ether5,ether12 vlan-ids=27
add bridge=bridge1 tagged=sfp-sfpplus1,sfp-sfpplus2 untagged=ether6 vlan-ids=40
add bridge=bridge1 tagged=sfp-sfpplus1,sfp-sfpplus2 untagged=ether8 vlan-ids=38
add bridge=bridge1 tagged=sfp-sfpplus1,sfp-sfpplus2 untagged=ether9 vlan-ids=14
add bridge=bridge1 tagged=sfp-sfpplus1,ether9,sfp-sfpplus2 vlan-ids=21
add bridge=bridge1 tagged=sfp-sfpplus1,sfp-sfpplus2 untagged=ether7 vlan-ids=39
add bridge=bridge1 tagged=sfp-sfpplus1,sfp-sfpplus2,ether14 vlan-ids=42
add bridge=bridge1 tagged=sfp-sfpplus1,ether15,sfp-sfpplus2 vlan-ids=3
add bridge=bridge1 tagged=sfp-sfpplus1,ether13,sfp-sfpplus2 vlan-ids=4
add bridge=bridge1 tagged=sfp-sfpplus1,sfp-sfpplus2,ether15 vlan-ids=5
add bridge=bridge1 tagged=sfp-sfpplus1,sfp-sfpplus2,ether14 vlan-ids=6
add bridge=bridge1 tagged=sfp-sfpplus1,sfp-sfpplus2,ether15 vlan-ids=7
add bridge=bridge1 tagged=sfp-sfpplus1,sfp-sfpplus2,ether13 vlan-ids=8
add bridge=bridge1 tagged=sfp-sfpplus1,sfp-sfpplus2,ether14 vlan-ids=10
add bridge=bridge1 tagged=sfp-sfpplus1,sfp-sfpplus2,ether14 vlan-ids=11
add bridge=bridge1 tagged=sfp-sfpplus1,sfp-sfpplus2,ether14 vlan-ids=12
add bridge=bridge1 tagged=sfp-sfpplus1,sfp-sfpplus2,ether15 vlan-ids=13
add bridge=bridge1 tagged=sfp-sfpplus1,ether15,sfp-sfpplus2 vlan-ids=17
add bridge=bridge1 tagged=sfp-sfpplus1,ether13,sfp-sfpplus2 vlan-ids=18
add bridge=bridge1 tagged=sfp-sfpplus1,ether15,sfp-sfpplus2 vlan-ids=19
add bridge=bridge1 tagged=sfp-sfpplus1,ether15,sfp-sfpplus2 vlan-ids=20
add bridge=bridge1 tagged=sfp-sfpplus1,sfp-sfpplus2,ether14 vlan-ids=25
add bridge=bridge1 tagged=sfp-sfpplus1,sfp-sfpplus2,ether15 vlan-ids=26
add bridge=bridge1 tagged=sfp-sfpplus1,sfp-sfpplus2,ether15 vlan-ids=28
add bridge=bridge1 tagged=sfp-sfpplus1,sfp-sfpplus2,ether15 vlan-ids=29
add bridge=bridge1 tagged=sfp-sfpplus1,sfp-sfpplus2,ether14 vlan-ids=30
add bridge=bridge1 tagged=sfp-sfpplus1,sfp-sfpplus2,ether14 vlan-ids=31
add bridge=bridge1 tagged=sfp-sfpplus1,sfp-sfpplus2,ether14 vlan-ids=32
add bridge=bridge1 tagged=sfp-sfpplus1,sfp-sfpplus2,ether14 vlan-ids=33
add bridge=bridge1 tagged=sfp-sfpplus1,sfp-sfpplus2,ether14 vlan-ids=34
add bridge=bridge1 tagged=sfp-sfpplus1,sfp-sfpplus2,ether15 vlan-ids=37
add bridge=bridge1 tagged=sfp-sfpplus1,sfp-sfpplus2,ether14 vlan-ids=41
add bridge=bridge1 tagged=sfp-sfpplus1,sfp-sfpplus2,ether14 vlan-ids=43
add bridge=bridge1 tagged=sfp-sfpplus1,sfp-sfpplus2,ether14 vlan-ids=44
add bridge=bridge1 tagged=sfp-sfpplus1,sfp-sfpplus2,ether15,ether13 vlan-ids=51
add bridge=bridge1 tagged=sfp-sfpplus1,sfp-sfpplus2,ether15 vlan-ids=52
add bridge=bridge1 tagged=sfp-sfpplus1,sfp-sfpplus2,ether15 vlan-ids=53
add bridge=bridge1 tagged=sfp-sfpplus1,ether14,sfp-sfpplus2 vlan-ids=61
add bridge=bridge1 tagged=sfp-sfpplus1,ether14,sfp-sfpplus2 vlan-ids=62
add bridge=bridge1 tagged=sfp-sfpplus1,ether14,sfp-sfpplus2 vlan-ids=63
add bridge=bridge1 tagged=sfp-sfpplus1,ether14,sfp-sfpplus2 vlan-ids=64
add bridge=bridge1 tagged=sfp-sfpplus1,ether15,sfp-sfpplus2 vlan-ids=71
add bridge=bridge1 tagged=sfp-sfpplus1,ether15,sfp-sfpplus2 vlan-ids=69
add bridge=bridge1 tagged=sfp-sfpplus1,ether15,sfp-sfpplus2 vlan-ids=73
add bridge=bridge1 tagged=sfp-sfpplus1,ether15,sfp-sfpplus2 vlan-ids=74
add bridge=bridge1 tagged=sfp-sfpplus1,ether14,sfp-sfpplus2 vlan-ids=75
add bridge=bridge1 tagged=sfp-sfpplus1,ether14,sfp-sfpplus2 vlan-ids=76
add bridge=bridge1 tagged=sfp-sfpplus1,ether14,sfp-sfpplus2 vlan-ids=77
add bridge=bridge1 tagged=sfp-sfpplus1,ether14,sfp-sfpplus2 vlan-ids=78
add bridge=bridge1 tagged=sfp-sfpplus1,sfp-sfpplus2,ether13 vlan-ids=100
add bridge=bridge1 tagged=sfp-sfpplus1,ether13,sfp-sfpplus2 vlan-ids=101
add bridge=bridge1 tagged=sfp-sfpplus1,ether13,sfp-sfpplus2 vlan-ids=104
add bridge=bridge1 tagged=sfp-sfpplus1,ether13,sfp-sfpplus2 vlan-ids=160
add bridge=bridge1 tagged=sfp-sfpplus1,ether13,sfp-sfpplus2 vlan-ids=203
add bridge=bridge1 tagged=sfp-sfpplus1,ether13,sfp-sfpplus2 vlan-ids=204
add bridge=bridge1 tagged=sfp-sfpplus1,ether13,sfp-sfpplus2 vlan-ids=205
add bridge=bridge1 tagged=sfp-sfpplus1,ether13,sfp-sfpplus2 vlan-ids=206
add bridge=bridge1 tagged=sfp-sfpplus1,ether13,sfp-sfpplus2 vlan-ids=218
add bridge=bridge1 tagged=sfp-sfpplus1,ether13,sfp-sfpplus2 vlan-ids=219
add bridge=bridge1 tagged=sfp-sfpplus1,ether13,sfp-sfpplus2 vlan-ids=223
add bridge=bridge1 tagged=sfp-sfpplus1,sfp-sfpplus2,ether13 vlan-ids=224
add bridge=bridge1 tagged=sfp-sfpplus1,sfp-sfpplus2,ether13 vlan-ids=225
add bridge=bridge1 tagged=sfp-sfpplus1,sfp-sfpplus2,ether13 vlan-ids=226
add bridge=bridge1 tagged=sfp-sfpplus1,sfp-sfpplus2,ether13 vlan-ids=227
add bridge=bridge1 tagged=sfp-sfpplus1,sfp-sfpplus2,ether13 vlan-ids=228
add bridge=bridge1 tagged=sfp-sfpplus1,sfp-sfpplus2,ether13 vlan-ids=229
add bridge=bridge1 tagged=sfp-sfpplus1,sfp-sfpplus2,ether13 vlan-ids=230
add bridge=bridge1 tagged=sfp-sfpplus1,sfp-sfpplus2,ether13 vlan-ids=233
add bridge=bridge1 tagged=sfp-sfpplus1,sfp-sfpplus2,ether13 vlan-ids=243
add bridge=bridge1 tagged=sfp-sfpplus1,sfp-sfpplus2,ether13 vlan-ids=244
add bridge=bridge1 tagged=sfp-sfpplus1,sfp-sfpplus2,ether13 vlan-ids=248
add bridge=bridge1 tagged=sfp-sfpplus1,sfp-sfpplus2,ether13 vlan-ids=250
add bridge=bridge1 tagged=sfp-sfpplus1,sfp-sfpplus2,ether13 vlan-ids=251
add bridge=bridge1 tagged=sfp-sfpplus1,sfp-sfpplus2,ether13 vlan-ids=252
add bridge=bridge1 tagged=sfp-sfpplus1,sfp-sfpplus2,ether13 vlan-ids=253
add bridge=bridge1 tagged=sfp-sfpplus1,sfp-sfpplus2,ether13 vlan-ids=255
add bridge=bridge1 tagged=sfp-sfpplus1,sfp-sfpplus2,ether13 vlan-ids=257
add bridge=bridge1 tagged=sfp-sfpplus1,sfp-sfpplus2,ether13 vlan-ids=260
add bridge=bridge1 tagged=sfp-sfpplus1,sfp-sfpplus2,ether13 vlan-ids=261
add bridge=bridge1 tagged=sfp-sfpplus1,sfp-sfpplus2,ether13 vlan-ids=262
add bridge=bridge1 tagged=sfp-sfpplus1,sfp-sfpplus2,ether13 vlan-ids=263
add bridge=bridge1 tagged=sfp-sfpplus1,sfp-sfpplus2,ether13 vlan-ids=264
add bridge=bridge1 tagged=sfp-sfpplus1,sfp-sfpplus2,ether13 vlan-ids=265
add bridge=bridge1 tagged=sfp-sfpplus1,sfp-sfpplus2,ether13 vlan-ids=266
add bridge=bridge1 tagged=sfp-sfpplus1,sfp-sfpplus2,ether13 vlan-ids=267
add bridge=bridge1 tagged=sfp-sfpplus1,sfp-sfpplus2,ether13 vlan-ids=268
add bridge=bridge1 tagged=sfp-sfpplus1,sfp-sfpplus2,ether14 vlan-ids=300
add bridge=bridge1 tagged=sfp-sfpplus1,sfp-sfpplus2,ether14 vlan-ids=301
add bridge=bridge1 tagged=sfp-sfpplus1,sfp-sfpplus2,ether14 vlan-ids=302
add bridge=bridge1 tagged=sfp-sfpplus1,sfp-sfpplus2,ether14 vlan-ids=303
add bridge=bridge1 tagged=sfp-sfpplus1,sfp-sfpplus2,ether14 vlan-ids=304
add bridge=bridge1 tagged=sfp-sfpplus1,sfp-sfpplus2,ether14 vlan-ids=305
add bridge=bridge1 tagged=sfp-sfpplus1,sfp-sfpplus2,ether14 vlan-ids=306
add bridge=bridge1 tagged=sfp-sfpplus1,sfp-sfpplus2,ether13 vlan-ids=1001
add bridge=bridge1 tagged=sfp-sfpplus1,sfp-sfpplus2,ether13 vlan-ids=1002
add bridge=bridge1 tagged=sfp-sfpplus1,sfp-sfpplus2 untagged=ether13,ether14,ether15 vlan-ids=98
add bridge=bridge1 tagged=sfp-sfpplus1,ether14,sfp-sfpplus2 vlan-ids=70,130
add bridge=bridge1 tagged=sfp-sfpplus1,sfp-sfpplus2 vlan-ids=2
add bridge=bridge1 tagged=sfp-sfpplus1,sfp-sfpplus2,sfp-sfpplus3,sfp-sfpplus4 vlan-ids=111
add bridge=bridge1 tagged=sfp-sfpplus1,sfp-sfpplus2,ether14 vlan-ids=45
add bridge=bridge1 tagged=sfp-sfpplus1,ether14,sfp-sfpplus2 vlan-ids=79
add address=192.168.3.23/24 interface=managment network=192.168.3.0
add fast-forward=no frame-types=admit-only-vlan-tagged name=bridge1 protocol-mode=none vlan-filtering=yes
set [ find default-name=ether1 ] rx-flow-control=on speed=100Mbps tx-flow-control=on
set [ find default-name=ether2 ] rx-flow-control=on speed=100Mbps tx-flow-control=on
set [ find default-name=ether3 ] rx-flow-control=on speed=100Mbps tx-flow-control=on
set [ find default-name=ether4 ] poe-voltage=low speed=100Mbps
set [ find default-name=ether5 ] rx-flow-control=on speed=100Mbps tx-flow-control=on
set [ find default-name=ether6 ] poe-voltage=low speed=100Mbps
set [ find default-name=ether7 ] poe-out=forced-on rx-flow-control=on speed=100Mbps tx-flow-control=on
set [ find default-name=ether8 ] poe-voltage=low rx-flow-control=on tx-flow-control=on
set [ find default-name=ether9 ] poe-voltage=low speed=100Mbps
set [ find default-name=ether10 ] full-duplex=no poe-voltage=low speed=10Mbps
set [ find default-name=ether11 ] poe-voltage=low
set [ find default-name=ether19 ]
set [ find default-name=ether20 ]
set [ find default-name=ether21 ]
set [ find default-name=ether22 ] advertise=10M-half,10M-full,100M-half,100M-full auto-negotiation=no speed=100Mbps
set [ find default-name=ether23 ]
set [ find default-name=ether24 ]
set [ find default-name=sfp-sfpplus1 ] advertise=1000M-half,1000M-full auto-negotiation=no
/interface vlan
add interface=bridge1 name=vlan99_mngmt vlan-id=99
/ip hotspot profile
add name=dhcp_pool4 ranges=192.168.10.20-192.168.10.254
/user group
add bridge=bridge1 interface=ether4 pvid=30
add bridge=bridge1 interface=ether5 pvid=62
add bridge=bridge1 interface=ether6 pvid=11
add bridge=bridge1 interface=ether7 pvid=61
add bridge=bridge1 interface=ether8 pvid=63
add bridge=bridge1 interface=ether10 pvid=41
add bridge=bridge1 interface=ether1 pvid=1233
add bridge=bridge1 interface=ether3 pvid=10
add bridge=bridge1 interface=ether9 pvid=75
add bridge=bridge1 interface=ether11 pvid=10
add bridge=bridge1 interface=ether12 pvid=10
add bridge=bridge1 interface=ether21 pvid=10
add bridge=bridge1 interface=ether22 pvid=10
add bridge=bridge1 interface=ether23 pvid=10
add bridge=bridge1 interface=ether24 pvid=10
add bridge=bridge1 interface=sfp-sfpplus2 pvid=10
add bridge=bridge1 interface=ether20 pvid=79
add bridge=bridge1 frame-types=admit-only-vlan-tagged interface=ether19 pvid=1234
add bridge=bridge1 tagged=ether1,ether2,ether3,ether4,ether5,ether6,ether7,ether8,ether9,ether10,ether11,ether12,sfp-sfpplus1,bridge1,ether20 vlan-ids=
99
add bridge=bridge1 tagged=ether1,ether3 vlan-ids=6
add bridge=bridge1 tagged=ether1 untagged=ether21,ether3,ether20,ether11,ether22,ether23,ether24,ether12,sfp-sfpplus2 vlan-ids=10
add bridge=bridge1 tagged=ether1,ether3 vlan-ids=12
add bridge=bridge1 tagged=ether1,ether7 vlan-ids=25
add bridge=bridge1 tagged=ether1 untagged=ether4 vlan-ids=30
add bridge=bridge1 tagged=ether1,ether7 vlan-ids=32
add bridge=bridge1 tagged=ether1,ether5 vlan-ids=33
add bridge=bridge1 tagged=ether1,ether5 vlan-ids=34
add bridge=bridge1 tagged=ether1 untagged=ether10 vlan-ids=41
add bridge=bridge1 tagged=ether1,ether2 vlan-ids=42,43,44,45
add bridge=bridge1 tagged=ether1 untagged=ether7 vlan-ids=61
add bridge=bridge1 tagged=ether1 untagged=ether5 vlan-ids=62
add bridge=bridge1 tagged=ether1 untagged=ether8 vlan-ids=63
add bridge=bridge1 tagged=ether1,sfp-sfpplus1 vlan-ids=300,301,302,303,304,305,306
add bridge=bridge1 tagged=ether1 untagged=ether6 vlan-ids=11
add bridge=bridge1 tagged=ether1,ether9 vlan-ids=76,77,78
add bridge=bridge1 tagged=ether1 untagged=ether9 vlan-ids=75
add bridge=bridge1 tagged=ether1,ether2 vlan-ids=70,130
add bridge=bridge1 tagged=ether1 untagged=ether20 vlan-ids=79
add address=10.12.12.1/24 disabled=yes interface=ether3 network=10.12.12.0
add address=192.168.161.2/24 disabled=yes interface=ether1 network=192.168.161.0
add address=192.168.3.29/24 interface=vlan99_mngmt network=192.168.3.0
set allow-remote-requests=yes servers=8.8.8.8
add action=src-nat chain=srcnat disabled=yes src-address=192.168.4.0/24 to-addresses=192.168.100.100
add distance=1 gateway=192.168.3.1
