hi,
i have a question:
I have a firewall with some VLAN configured.
Behind the firewall i have a Mikrotik configured as a switch like written here: https://wiki.mikrotik.com/wiki/Manual:Switch_Chip_Features#Setup_Examples
My special requirement is: I have to connect a second Mikrotik behind the first one (i need to “duplicate” the Port2)
I tried some things, Mikrotik 1 is working, but Mikrotik 2 is not working.
Any idea?
Thanks.
List your config on Tik1 (/export hide-senstive compact) and indicate who you want to connect: from what interface to which?
That is Mikrotik 1:
add name=bridge1
add bridge=bridge1 interface=ether2 hw=yes
add bridge=bridge1 interface=ether3 hw=yes
add bridge=bridge1 interface=ether4 hw=yes
add bridge=bridge1 interface=ether5 hw=yes
add ports=ether2,ether3 switch=switch1 vlan-id=21
add ports=ether2,ether4 switch=switch1 vlan-id=22
add ports=ether2,ether5 switch=switch1 vlan-id=23
set ether2 vlan-mode=secure vlan-header=add-if-missing
set ether3 vlan-mode=secure vlan-header=always-strip default-vlan-id=21
set ether4 vlan-mode=secure vlan-header=always-strip default-vlan-id=22
set ether5 vlan-mode=secure vlan-header=always-strip default-vlan-id=23
I would like to connect from Mikrotik 1 Port 3 to Mikrotik 2 Port 2.
I only need VLAN 22 + 23 on Mikrotik 1 and Mikrotik 2
Tik1 Port3 is access port: only untagged traffic for vlan 21 will pass.
If you want vlan 21 & 22 on Tik2, you’ll need to use Port2 of Tik1 as this one is trunk port.
Note: “set ether2 vlan-mode=secure vlan-header=add-if-missing” without saying which id doesn’t make sense
I understand.
But how to configure port3 on Mikrotik 1?
anav
April 30, 2019, 1:06pm
6
I cannot fathom how anyone could actually answer your question without a diagram of what you are trying to accomplish and a complete config (not just select snippets).
Sebastia must be a mind reading God!
/export hide-sensitive file=yourconfig
Here is the code from Mikrotik 1:
add name=bridge1
set 1 vlan-header=add-if-missing vlan-mode=secure
set 2 vlan-header=add-if-missing vlan-mode=secure
set 3 default-vlan-id=22 vlan-header=always-strip vlan-mode=secure
set 4 default-vlan-id=23 vlan-header=always-strip vlan-mode=secure
/ip hotspot profile
add name=dhcp_pool0 ranges=192.168.20.20-192.168.20.25
add address-pool=dhcp_pool0 disabled=no interface=ether1 name=dhcp1
add address=192.168.20.1/24 interface=ether1 network=192.168.20.0
add address=192.168.20.0/24 dns-server=8.8.8.8 gateway=192.168.20.1
Firewall —> Mik1 Port 2
Mik1 Port 3 —> Mik2 Port2
on Mik 1 and Mik 2 Port 4 i need VLAN 21
on Mik 1 and Mik 2 Port 5 i need VLAN 22
if firewall doing the vlan routing?
and both Tik’s are used as smart switches then?
If you use Tik1Port3 for connection to Tik2, then this port has to be cofigured as trunk too, just like Port2: so all vlans (or the relevant ones) present and all tagged.
That means only add this Code?
You’ll also need to:
indicate in which vlans it partiipates under /interface ethernet switch vlan
change from access to trunk under /interface ethernet switch port
anav
May 1, 2019, 5:47pm
11
Sits back eating melba toast and caviar drinking dry champagne watching Sebastia play whackamole!
Thanks to sebastia!
He is trying to help.
That’s it! Everything works!
Here the code of both Mikrotik
add name=bridge1
set 1 vlan-mode=secure
set 2 vlan-mode=secure
/ip hotspot profile
add ports=ether2,ether3,ether4 switch=switch1 vlan-id=22
add ports=ether2,ether3,ether5 switch=switch1 vlan-id=23
Thank you for helping me!
