2 network in same network
hello all
how can send data between 2 mikrotik, but same-one in the network cant show this ip.
i receive pppoe from wireless from mk1 and the router is in ether1 in mk2
mk1 and mk2 his relate by ether2 → ether2 (ether2 is public network)
what is the best method for solved the problem (IPsec, EoIP, VNP, … )
same-body help meeeeeeeeeee
nobody has the answer
http://catb.org/~esr/faqs/smart-questions.html
http://forum.mikrotik.com/t/getting-the-most-out-of-this-forum/40983/1
Try asking again with more details. What are you trying to accomplish? I read your question several times and I don’t understand it, I’m afraid. “2 network in same network” doesn’t make sense to me.
ok this is my network, i have 2 account PPPoE from ISP
my routers are in public 2
the mikrotik-2 is configure to load balancer the routers to clients.
my question is (how can connect direc the routers to IPS in she some network line) but I’m handing pppoe and the isp handing pppoe (so I do not want to mix the netrowk)
is there any way to send the PPPoE from public1 to public2 without private seeing anything
I still have absolutely no idea what you’re talking about. Sorry. Maybe someone else understands.
Your network is madness. The answer is to fix it not look for extra rolls of duct tape or crazy workarounds.
Router 1 and 2 have ports on the a network segment, that is also part of their upstream. what??
if you are trying to pppoe to the ISP from some router deep inside the LAN somewhere, EoIP link from there to the mikrotik (1) and use PPPoE client then.
