2 networks 1 gateway
I have one network192.168.1.0/24 with some specific software with gateway 192.168.1.1. Now I have network with internet gateway 192.168.2.0/24 gateway 192.168.2.1. How to route traffic on Mikrotik if I have only one NIC at client side. how to route both networks on one gateway. Can I somehow use two gateway under win XP.
Thanks !
did not get it - which is default GW wich is not
IMHO you just have to set routes correclty, like where is default GW and where to got to get to addditional network. just set correct signs where to transfer packets allong the route.
192.168.1.1 is default gw now. Can you give me some more help :slight_smile: I don’t know what you tell me to do.
thanks !
Can you provide a schematic diagram where the client, mikrotik and internet located in order to understand what do you mean?
