Hi Guys,
I am currently using default static route from my upstream provider on the ‘ether1’ interface, with the 1st network being advertised currently on the AS.
Example:
1st Network - ether1 - 66.123.1.0/22 (Router IP: 66.123.1.1)
2nd Network - ??? - 66.188.1.0/22
The ‘ether2’ port is currently connected to a network switch, where different servers are connected with IPs from the 1st network (66.123.1.0/22).
I am adding a new 2nd network (66.188.1.0/22) to the router, can I do the same and assign the new network to ether2 with the same switch? Or do I have to assign it on ether3 that is connected to a new VLAN or a new switch?
What would be ideal and recommended?
Thank you.
