Good morning, I’m trying to merge 2 ppoe clients, not as load balancing but trying to get both connections out with the same public IP, as if I were to merge them, is it possible to do it with mikrotik directly? A thousand thanks
Not sure what you mean.
Do you have two PPPOE WAN connections ( aka the router is a client to the ISP)
Same ISP, two different PPPOE logins?
Two different ISPs???
Yes, i got 4 PPoE cliente from 2 different ISP and i got a device that group them all.
For example:
i got 2 FTTC 100m/20m, iwould like them to “join” and be able to go out with the usual public IP
Like if i do i speed test i what to go 200M/40M. It is possible?
