hi there all
i have 2 adsl connection with diferent ISP
i alredy did setup 2 pppoe in my rb450 os 4.5
then in IP route i add a new route and as gateways i choose more than 1 gateway
i asign the 2 pppoe as gateway for my lan port
it looks ok
both of conections are used at same time
they do load balance and fail over at same time
but im getting problems in some online comunittis
facebook and its applications like texas hold em up i get disconected
same problem with youtube it stoops loading sometimes
another thing is that i cant reach maximum download
trafic of both pppoe 2M+2M i shoud get 4M output but max i got was 2.9M
any suggestion how to resove this problems
the problem is that im using PPPoE with dynamic ip
and the ppc need a ip interface so a my configuration the following
ip address
Abissnet PPPoE on ether 1 (on this pppoe connection i get always same ip)
Abissnet2 PPPoE on ether 2 (on this connection everery time i reconect i get another ip)
192.168.0.254/24 ether 3
im using rb 750
please post a configuration with the based on this connections
thanks in adv
