Hi everybody
I’ve 2 problems with the dude 3.4
1/ The first one is that the dude create a new similar network in discover mode. 2 clouds appear with the same links. ![]()
2/ I can’t configure the mail notification has i want… I juste want a mail if the status is down more than 1 min but i don’t know whitch timer should i configure. I’ve you got a example ? I’ve tester a lot of thing but nothing work like i want. Is it possible to have a notification if the status is unstable with a counter (ex: 5 instables = mail)
Thanks for you help
Cybertiti
