Hello There
I have a 8 subnet (255.255.255.248)
ethernet1 80.120.23.145 /29
ethernet2 80.120.23.146 /29
Gateway for both eth1 and eth2 80.120.23.144
ethernet4 192.168.0.1 /24 company
ethernet5 192.168.1.1 /24 guests
I want that the guests surf on ethernet 2
and that my company on ethernet 1
but i didn’t get it to work.
maybe somebody can explain me how to get this work?
and i am really a beginner on mikrotik.
Thanks a lot for your time and help
May I be the first to welcome you to the MikroTik forum!
First, you need to get both of your public ips on one interface. Like this:
add address=xx.xx.xx.02/24 interface=ether1
add address=xx.xx.xx.03/24 interface=ether1
Insure your default route is set ok:
add gateway=xx.xx.xx.01
The a srcnat (masquerade if one ip on interface)
add chain=srcnat action=src-nat to-addresses=xx.xx.xx.02
Change these to the correct ip addresses/subnets as necessary.
hi thanks for answer but there is one problem
now internet is working for guests and company thats fine
but i want
that guests surf with public ip 80.120.43.133
and company surf with public ip 80.120.43.134
I guessed that, but I like one change at a time. Now that your net is working, now we will “divide it up”.
add chain=srcnat action=src-nat src-address=192.168.1.0/24 to-addresses=80.120.43.133 place-before=0
add chain=srcnat action=src-nat src-address=192.168.0.0/24 to-addresses=80.120.43.134 place-before=0
This will “masquerade”:
192.168.1.0/24 to 80.120.43.133
192.168.0.0/24 to 80.120.43.134
Anything else should be covered by a default rule if necessary. The default rule should be the last rule in this list. Order is important here. That is why the “place-before=0” parameters.
