i have a ptp link between work and home, both are on same subnet unfortunatelly.
both devices of the ptp link are acting like routers - have masquerade configured.
this is the config on both (just the important stuff)
home SXT:
add address=192.168.2.52/24 interface=ether1 network=192.168.2.0
add address=192.168.38.2/24 interface=wlan1 network=192.168.38.0
add action=dst-nat chain=dstnat dst-port=50000 protocol=tcp to-addresses=
192.168.2.30 to-ports=3389
add action=dst-nat chain=dstnat dst-port=50002 protocol=tcp to-addresses=
192.168.2.25 to-ports=3389
add distance=1 gateway=192.168.38.1
work SXT:
add address=192.168.2.107/24 interface=ether1 network=192.168.2.0
add address=192.168.38.1/24 interface=wlan1 network=192.168.38.0
add action=src-nat chain=srcnat src-address=192.168.2.0/24 to-addresses=
192.168.38.2
add distance=1 gateway=192.168.2.1
i’m unable to make this to work.
i need to RDC into a local machine on my home network (later will config the same thing for office pc).
how to config that? i’m trying to rdc into 192.168.2.107:50002 which is my internal IP of work SXT that should do port forward to the home SXT which should then port forward to my home pc.
