2 routers with each ISP connected
i have the following setup where i need to sync NAT table between the 2 routers
router 1= 1 ISP connected
router 2= 1 ISP connected
we use the same ISP on both routers. but they seperate connections.
The routers are connected to each other by black fiber running OSPF betwwen.
we use BGP towards the ISP, but we are using NAT on both router.
Is it possible to sync NAT tables. so NAT are the same on both router
Not implemented yet on RouterOS, guess you’re referring to something like CARP/pfsync in FreeBSD.
Let support@mikrotik.com know that would be a desired feature.
thx for the quick reply. Ill email Mikrotik
