2 subnetworks and communication between them
Hello
I just configured 2 dhcp servers on 2 ports ether2 (192.168.22.0/24) and ether3 (192.168.33.0/24).
On RB751 :slight_smile:
I have one problem i can not ping computer form network (192.168.22.0/24) to network (192.168.33.0/24).
I can make ping to only gate from for example 192.168.22.254 to 192.168.33.1. ( but i want to make ping from 192.168.254 → 192.168.33.1 → 192.168.33.252)
Can you help me :slight_smile: ?
There are multiple possible reasons for it. First of all i suggest to check firewall settings on route ROS device.
Check the default gateway setting in your DHCP servers to ensure it is correct. Sounds like you don’t have a route back from the end host.
I have 192.168.22.1 gateway for network 192.168.22.0/24 and 192.168.33.0/24 gateway is 192.168.33.1 … 2 different gateway. This is good ? what i schould do?
yeah one gateway per subnet that’s correct.
  • have you checked th firewall?
  • some crazy nat rules ?
  • how about IP->Settings ? forwardIng on ?
