2 vpls tunns sum bandwidth
hello,
Here is my setup:
. . . . . . RB433AH . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . RB433AH
LAN1_1 — eth1 – vpls1 ----\ . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . /---- vpls1 – eth1 — LAN1_2
LAN2_1 — eth2 – vpls2 ----|-----------------[ 11n link (200mbps) ] -------------|---- vpls2 – eth2 — LAN2_2
. . . . . . . eth3 – vpls3 ----/ . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . -— vpls3 – eth3
doing download from LAN1_1 to LAN1_2 speed is 100mbps, that is ok for 100mbps lan interface
the problem is: while downloading from LAN1_1 to LAN1_2 with 100mbps, the bandwidh form LAN2_1 to LAN2_2 is very low (1-2mbps), and real sum bandwidth for all vpls tunnels is 100mbps (98mbps for vpls1 and 2mbps for vpsl2, or 70mbps for vpls1 and 30mbps for vpls2) never goes higher
BW test from RB to RB shows 200mbps
when downloading from LAN1_1 to LAN1_2 with 100mbps, BW test shows remaining ~100mbps.
WHERE IS THE PROBLEM?
tryed ROS V4 and V5 rc 3, the same…
No one?
Where's mikrotik's staff???
All right...
Conclusion - MT mst de
