I use RB450G with 2 WAN
Diagram is:
LAN1 → I rename this interface to WAN1 and connect it to First modem is (192.168.1.1)
LAN2 → I rename this interface to WAN2 and connect it to Second modem is (192.168.2.1)
LAN3 → maybe third modem
LAN4 → maybe fouth soon…
LAN5 → LAN network port that connect to switch and bullet2 HP ( The users connecting from lan5)
I made a hotspot and the users can connect from lan5 to my router.
Everything was ok since i connected my second modem to my RB.
Coz some users disconnect from msn messenger and connect again and disconnect and connect…
I have to make some rules for load balancing.
Anybody help me? This is my first message. Thx from now.
Unfortunately, the highest speed you will get is the speed of ADSL with highest speed, unless you use multiple downloads, like with download manager, it might appear as though you get 18 meg. This is load balancing. For what you want to do you would need line bonding, however with line bonding you need control of both routers. Your side and isp side, which does not happen very often.
