Hi, I have configured a RB2011 with 2 WAN and 2 LAN. Configuration below works fine. I also need to remote connect via winbox to RB2011. When i try to connect to public address doen’t work. It does work only wiith 1 WAN but not with 2 WANs. What’s wrong?
No idea why you are showing pre-routing.
The only thing I can say is that attempting to open a door to the router via your winbox port is unsafe and should be avoided.
If you need access to the router externally, then the proper way is via a VPN tunnel to the LAN side and then access the router from the LAN.
The example shows two but most people Ive seen make it 3 or four port knocks…
Would post your config here before attempting just use fake port numbers for that, but its important to get your input chain rules correct.
I would like to start with simple things. What is missing in the firewall filter rule to make it work? Once it works I can try to implement a vpn to access the router
