Hi, i have 3 Wans running perfectly, and always use the WAN3 as a gateway. If i want to use the others gateways just should to activate a mangle configuration that mark packets etc etc. I need to use the WAN1 as a default gateway without marking packets, but i don’t found any configuration about is. Is there any idea ??
As long as the default route uses the gateway it, you’re done. Make sure is it masqueraded.
That’s my routes configuration, after WAN-EPEC was my primary connection, since i added WAN-COOP it’s now my primary connection, but I want it to remains WAN-EPEC as always
That’s my WAN-EPEC configuration (after my primary connection)
That’s the new WAN-COOP, it’s a dynamic connection and i want to i want it to be my secondary connection
change your distance. Have the lowest number to your main connection
Ok, but that’s no possible in dynamic connections. I kept searching in my Mikrotik router configurations and i found it !! in DHCP client exists the option.
Thanks a lot!
Default Route Distance can be set also on pppoe-client, vpn clients, etc: Dial-out tab.
