Hi
please can you assist with this one
I have 2 WAN connections 1 fibre and 1 DSL I want to be able to assign some of my PPPoE clients onto the fibre connection and some to DSL how can this be achieved
thanks in advance
Hi
thanks in advance
The best way of doing it depends on what the split is between customers.
As an example, if you place one WAN connection in its own VRF you can then add policy routing rules to use that VRF’s routing table for outbound requests from certain source IP addresses.
okay tell me more, because currently there is no split between customers they are all connected using a PPPoE server on the Mikrotik but now because of more data being required we got an additional line to cater for the customers that are more data hungry
i’ve never done VRF so if possible can you take me through how i can achieve this
thanks
