2 wan ip 1 gateway 1lan
what i want to do is use 2 wan ips both pointing to a single a gteway the diffrence between the two ips is for example ip1 is 128kbps and ip2 is 1024 kbps
so when the router send packets to the gate way it should send 4 through ip2 and 2 through ip1
any pointers will be a grate help
Read the manual on load balancing
A question for you, how to do load balancing with failover with 2 adsl modems if it asign ip dhcp address?
as a rule, gateway address do not change =) so don’t worry about dhcp
