2 wan load balancing with failover problems
I have configured my router board with YouTube mikrotik video for 2 wan load balancing and failover but I have some problems.
  • open news pages is very slow as dns server has some problems to resolve host
  • YouTube open slowly an frequently stop during video watching
  • I have a raspberry with homeassistant and it can not open from outside . If I disable one of wan I can access correctly
What can I do? For raspberry connected alone on ethernet port there is a way o rules to setup to employ only a wan outside load balancing?
Hey
For starters, post your current config: /export hide-sensitive (in-between code tags)
hi,
this is my configuration wan1 static ip 192.168.89.10 and wan2 192.168.88.10 internal lan 192.168.1.0
aug/21/2019 09:24:31 by RouterOS 6.45.3
software id = ZS3Y-57J1
model = RouterBOARD 962UiGS-5HacT2HnT
serial number = 8A77094AEC63
add admin-mac=B8:69:F4:39:B2:91 auto-mac=no comment=defconf name=bridge
set [ find default-name=ether1 ] comment=ICARO name=WAN1
set [ find default-name=ether2 ] comment=HO disabled=yes name=WAN2
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=20/40mhz-XX
disabled=no distance=indoors frequency=auto installation=indoor mode=
ap-bridge ssid=domus wireless-protocol=802.11
set [ find default-name=wlan2 ] band=5ghz-a/n/ac channel-width=20/40/80mhz-XXXX
ap-bridge ssid=F3272Fast wireless-protocol=802.11
add comment=defconf name=WAN
add comment=defconf name=LAN
set [ find default=yes ] authentication-types=wpa2-psk eap-methods=“” mode=
dynamic-keys supplicant-identity=MikroTik
/ip hotspot profile
add name=pool1 ranges=192.168.1.10-192.168.1.254
add address-pool=pool1 disabled=no interface=bridge name=dhcp1
add bridge=bridge comment=defconf interface=sfp1
add bridge=bridge comment=defconf interface=wlan2
add comment=defconf interface=WAN1 list=WAN
add interface=WAN2 list=WAN
add list=WAN
add address=192.168.1.1/24 comment=defconf interface=bridge network=192.168.1.0
add address=192.168.88.10/24 interface=WAN2 network=192.168.88.0
add address=192.168.89.10/24 comment=M1100_usb_ip_fisso_dmz disabled=yes
network=192.168.89.0
add address=192.168.89.10/24 comment=m1100_LAN_dmz interface=WAN1 network=
192.168.89.0
/ip arp
add address=192.168.1.65 interface=bridge mac-address=B8:27:EB:FC:65:EF
/ip dhcp-client
add dhcp-options=hostname,clientid
/ip dhcp-server lease
add address=192.168.1.65 mac-address=B8:27:EB:FC:65:EF
add address=192.168.1.0/24 dns-server=8.8.8.8,8.8.4.4 gateway=192.168.1.1
set allow-remote-requests=yes servers=8.8.8.8,8.8.4.4
/ip dns static
add address=192.168.1.1 comment=defconf name=router.lan
add address=8.8.8.8 name=google
/ip firewall address-list
add address=192.168.1.1-192.168.1.2 list=router
add action=accept chain=input comment=
“defconf: accept established,related,untracked” connection-state=
add action=accept chain=input comment=“defconf: accept ICMP” protocol=icmp
add action=accept chain=forward comment=“defconf: accept in ipsec policy”
ipsec-policy=in,ipsec
add action=accept chain=forward comment=“defconf: accept out ipsec policy”
ipsec-policy=out,ipsec
add action=fasttrack-connection chain=forward comment=“defconf: fasttrack”
“defconf: accept established,related, untracked” connection-state=
add action=fasttrack-connection chain=forward dst-port=53 protocol=tcp
add action=fasttrack-connection chain=forward dst-port=53 protocol=udp
/ip firewall mangle
add action=accept chain=prerouting comment=wan1_icaro_prerouting dst-address=
192.168.89.0/24 in-interface=bridge
add action=accept chain=prerouting comment=wan2_ho_prerouting_wan2 dst-address=
192.168.88.0/24 in-interface=bridge
add action=mark-connection chain=prerouting connection-mark=no-mark
in-interface=WAN1 new-connection-mark=WAN1_conn passthrough=yes
in-interface=WAN2 new-connection-mark=WAN2_conn passthrough=yes
dst-address-type=!local in-interface=bridge new-connection-mark=WAN1_conn
passthrough=yes per-connection-classifier=both-addresses:2/0
dst-address-type=!local in-interface=bridge new-connection-mark=WAN2_conn
passthrough=yes per-connection-classifier=both-addresses:2/1
add action=mark-routing chain=prerouting connection-mark=WAN1_conn
in-interface=bridge new-routing-mark=to_WAN1 passthrough=yes
add action=mark-routing chain=prerouting connection-mark=WAN2_conn
in-interface=bridge new-routing-mark=to_WAN2 passthrough=yes
add action=mark-routing chain=output connection-mark=WAN1_conn
add action=mark-routing chain=output connection-mark=WAN2_conn
add action=accept chain=prerouting comment=router dst-address-list=router
add action=accept chain=forward comment=dns port=53 protocol=tcp
add action=accept chain=forward comment=dns port=53 protocol=udp
add action=accept chain=forward packet-mark=“client-dw -pk” port=
80,443,5222,5223,5228 protocol=tcp
add action=masquerade chain=srcnat comment=“defconf: masquerade” ipsec-policy=
out,none out-interface=WAN1
out,none out-interface=WAN2
add action=dst-nat chain=dstnat dst-port=53 protocol=udp src-address=
192.168.1.65 to-addresses=8.8.8.8
add check-gateway=ping distance=1 gateway=192.168.89.1 routing-mark=to_WAN1
add check-gateway=ping distance=5 gateway=192.168.88.1 routing-mark=to_WAN2
add comment=static_ip_nodhcp distance=1 gateway=192.168.88.1
add distance=1 gateway=192.168.89.1
/system clock
set time-zone-name=Europe/Rome
/system ntp client
set enabled=yes primary-ntp=37.247.53.178 secondary-ntp=80.211.178.99
/system ntp server
set broadcast=yes enabled=yes
/tool mac-server
/tool mac-server mac-winbox
you should remove fasttrack (action=fasttrack-connection, 3 instances), as it’s not compatible with loadbalancing
“add action=accept chain=prerouting comment=router dst-address-list=router” should be at the beginning of chain / before all LB logic
your default routes should have different distances: ex 1 & 2
Thanks for help, I removed fast track entities but I don’t know how to move that
add action=accept chain=prerouting comment=router dst-address-list=router" should be at the beginning of chain / before all LB logic
lol,
sorry i’m new on mikrotik.. i did.. litterally move up on list :slight_smile:
With distance i can modify ratio between use of two wan?
because i would use second wan less than first one, but i don’t know if it’s possible to achieve that too
the default routes are only relevant in context of fail-over: each connection gets assigned to either Wan1 or Wan2 in mangling, only when that link is not up will the default be relevant.
the current load balancing is 50/50
thanks again ..
is there a way to set 80/20 for example?
or stop on max mb reached dayly from wan2?
Not directly, but you can achieve this by being creative: repeat a link multiple times, for 80/20, pretend you have 5 links each good for 20% of traffic: wan1,wan1,wan1,wan1,wan2
Another option, is bandwidth based load-balancing: http://forum.mikrotik.com/t/dual-wan-setup-with-wan2-taking-over-once-wan1-has-hit-8mb-download-threshhold/132503/1
you would have to script that: on regular basis check stats on wanX and if condition met, switch to other. then at midnight switch to default one again.
Hi, I update this post because I changed one of the LTE modem..now a Huawei b715 and I setup to connect by a static DMZ up to the mikrotik router.
The problem is that it is ok for two five seconds then only the internet connection drop. On routes I had two rules that set the gateway on Huawei and check by ping if is reachable. Now internet drop as the gateway went unrachable.
What would be the reason ?..DMZ on Huawei does not work properly or could be something else to set up.
