Hi Everyone,
I just bought a Mikrotik Hex router and my goals are:
- attach 2 WAN in loadbalancing (Maybe 1 in failover) an attach to it 1 LAN;
- say that some group of IP instead need to use directly and only use the failover WAN (like using this for my homelab traffic without impacting on the user connection).
Just to give additional details I already have two router, provided from the ISP, that connect to the internet:
- Faster one (to be used by the user) that you can connect to it and have an ip on the lan 192.168.3.0/24 => I will call it WAN1
- Second one (to be used as failover/by the homelab/) that you can connect to it and have an ip on the lan 192.168.1.0/24 => I will call it WAN2
And I would like that the Mikrotik router create the LAN on 192.168.4.0/24 where everything is connected and reachable (user pc and homelab).
I already done it with a TP-LINK Router/Load Balancer, but it works only to 100Mbit. Now I changed it with this Microtik because it support the 1Gibabit and with the purpose in future to be able to add more detailed configuration (the TP-LINK is easy to configure, but a lot basic things seems really impossible to configure).
For the goals 1) I tried to follow this wiki:
https://wiki.mikrotik.com/Manual:PCC
So I tried to edit the wiki quick start for impatient in this way:
# oct/30/2024 18:36:58 by RouterOS 6.49.13
# software id = NRBT-RFM0
# model = RB760iGS
# serial number = HGJ09ZBKGJZ
set [ find default-name=ether1 ] name=WAN1
set [ find default-name=ether2 ] name=WAN2
set [ find default-name=ether3 ] name=LAN3
set [ find default-name=ether4 ] name=LAN4
set [ find default-name=ether5 ] name=LAN5
#/interface list
#add name=WAN
#add name=LAN
add interface=WAN1 list=WAN
add interface=WAN2 list=WAN
add interface=LAN3 list=LAN
add interface=LAN4 list=LAN
add interface=LAN5 list=LAN
add interface=sfp1 list=LAN
/ ip address
add address=192.168.4.1/24 network=192.168.4.0 broadcast=192.168.4.255 interface=LAN5
add address=192.168.3.1/24 network=192.168.3.0 broadcast=192.168.3.255 interface=WAN1
add address=192.168.1.1/24 network=192.168.1.0 broadcast=192.168.1.255 interface=WAN2
/ ip firewall mangle
add chain=prerouting dst-address=192.168.3.1/24 action=accept in-interface=LAN5
add chain=prerouting dst-address=192.168.1.1/24 action=accept in-interface=LAN5
add chain=prerouting in-interface=WAN1 connection-mark=no-mark action=mark-connection new-connection-mark=WAN1_conn
add chain=prerouting in-interface=WAN2 connection-mark=no-mark action=mark-connection new-connection-mark=WAN2_conn
add chain=prerouting in-interface=LAN5 connection-mark=no-mark dst-address-type=!local per-connection-classifier=both-addresses:2/0 action=mark-connection new-connection-mark=WAN1_conn
add chain=prerouting in-interface=LAN5 connection-mark=no-mark dst-address-type=!local per-connection-classifier=both-addresses:2/1 action=mark-connection new-connection-mark=WAN2_conn
add chain=prerouting connection-mark=WAN1_conn in-interface=LAN5 action=mark-routing new-routing-mark=to_WAN1
add chain=prerouting connection-mark=WAN2_conn in-interface=LAN5 action=mark-routing new-routing-mark=to_WAN2
add chain=output connection-mark=WAN1_conn action=mark-routing new-routing-mark=to_WAN1
add chain=output connection-mark=WAN2_conn action=mark-routing new-routing-mark=to_WAN2
/ ip route
add dst-address=0.0.0.0/0 gateway=192.168.3.1 routing-mark=to_WAN1 check-gateway=ping
add dst-address=0.0.0.0/0 gateway=192.168.1.1 routing-mark=to_WAN2 check-gateway=ping
add dst-address=0.0.0.0/0 gateway=192.168.3.1 distance=1 check-gateway=ping
add dst-address=0.0.0.0/0 gateway=192.168.1.1 distance=2 check-gateway=ping
/ ip firewall nat
add chain=srcnat out-interface=WAN1 action=masquerade
add chain=srcnat out-interface=WAN2 action=masquerade
The first problem is that in the terminal just using the import command didn’t work good because said that some interface already exist. So the problem was that I don’t know how to say “rewrite every configuration and just import this” and this means that the new configuration go in conflict with which the existing one. So that I just include command by command in the terminal interface (looking at what already exist and avoiding it) and then re-export the entire configuration to show it to you, and that’s it:
# jan/02/1970 00:05:45 by RouterOS 6.49.13
# model = RB760iGS
add admin-mac=D4:01:C3:C9:39:58 auto-mac=no comment=defconf name=bridge
add comment=defconf name=WAN
add comment=defconf name=LAN
add name=dhcp ranges=192.168.88.10-192.168.88.254
add address-pool=dhcp disabled=no interface=bridge name=defconf
add bridge=bridge comment=defconf interface=WAN2
add bridge=bridge comment=defconf interface=LAN3
add bridge=bridge comment=defconf interface=LAN4
add bridge=bridge comment=defconf interface=LAN5
add bridge=bridge comment=defconf interface=sfp1
add comment=defconf interface=WAN1 list=WAN
192.168.88.0
add address=192.168.4.1/24 interface=LAN5 network=192.168.4.0
add address=192.168.3.1/24 interface=WAN1 network=192.168.3.0
add address=192.168.1.1/24 interface=WAN2 network=192.168.1.0
/ip dhcp-client
add comment=defconf disabled=no interface=WAN1
192.168.88.1
set allow-remote-requests=yes
/ip dns static
established,related,untracked
invalid
in-interface-list=!LAN
ipsec-policy=in,ipsec
ipsec-policy=out,ipsec
connection-state=invalid
/ip firewall mangle
# in/out-interface matcher not possible when interface (LAN5) is slave - use master instead (bridge)
add action=accept chain=prerouting dst-address=192.168.3.0/24 in-interface=\
LAN5
add action=accept chain=prerouting dst-address=192.168.1.0/24 in-interface=\
LAN5
add action=mark-connection chain=prerouting connection-mark=no-mark \
in-interface=WAN1 new-connection-mark=WAN1_conn
# in/out-interface matcher not possible when interface (WAN2) is slave - use master instead (bridge)
# bad new connection mark
in-interface=WAN2
in-interface=WAN2
in-interface=WAN2 new-connection-mark=WAN2_conn
dst-address-type=!local in-interface=LAN5 new-connection-mark=WAN1_conn \
dst-address-type=!local in-interface=LAN5 new-connection-mark=WAN2_conn \
add action=mark-routing chain=prerouting connection-mark=WAN1_conn \
in-interface=LAN5 new-routing-mark=to_WAN1
add action=mark-routing chain=prerouting connection-mark=WAN2_conn \
in-interface=LAN5 new-routing-mark=to_WAN2
add action=mark-routing chain=output connection-mark=WAN1_conn \
add action=mark-routing chain=output connection-mark=WAN2_conn \
add action=masquerade chain=srcnat out-interface=WAN1
add action=masquerade chain=srcnat out-interface=WAN2
add check-gateway=ping distance=1 gateway=192.168.3.1 routing-mark=to_WAN1
add check-gateway=ping distance=1 gateway=192.168.1.1 routing-mark=to_WAN2
add check-gateway=ping distance=2 gateway=192.168.1.1
/tool mac-server
/tool mac-server mac-winbox
So the result is that I have a lot of error like:
that not being an expert I don’t know what does it mean and how to fix it. Also I’m recognizing that I have a lot of extra line of code that I didn’t input.
Also connection to the internet work “strange” because I was able to reach google for searchign things but then I wasn’t able to open any other page.
I thing I’m very far to the solution even if what I need seems “simple” that is not for me to configure. So that, is there any step-by-step how-to that can I follow? Maybe I’m not the first that want to ioad balance 2 WAN connection.
Thanks in advance,
Neptune.
