Hi, I need help with the following. I’m going to explain the setup and what I want to happen as simple as possible.
I have 2 ISP routers (192.168.178.1 & 192.168.177.1) going to 1 MT Router. 178.1 connected to Eth1 and 177.1 to Eth9. Eth6,7,8 is connected to server switches 1,2,3 respectively (eth6 connected to switch 2 is marked as root port?)
On the router I have a bridge called “LAN” (Eth ports 6,7,8).
Then I have a guest network (10.0.0.0/16) and an admin VLAN network (192.168.250.0/24).
Currently both the guest and admin network gets “internet” from only 1 ISP router (178.1). I want the guests on 10.0.0.0 to get internet from Eth1 and I want the admin VLAN to get internet from Eth9.
DHCP servers, etc. for both networks are configured as the network was working with only one ISP router (178.1) so I added ISP router 2 (177.1) on Eth9 to split internet usage between guest and admin VLAN network.
Can someone please help me to correctly finish this setup
